midiboxfx_-_midifiying_analog_gear [2007/01/04 13:54] DrBunsen Added resistor ladder idea |
midiboxfx_-_midifiying_analog_gear [2021/01/07 13:54] phatline [External links and resources:] |
Line 1: | Line 1: | ||
- | **Analog/Digital interfacing** | + | **Analog/Digital interfacing** |
- | This page has some ideas on how to mod analog gear, for instance fx/(drum)synths, so that they can be controlled by midi, in particular by midiboxes. | + | This page has some ideas on how to mod analog gear, for instance effects and (drum) synths, so that they can be controlled by MIDI, in particular by MIDIboxes. |
- | Like the rest of the WIKI this is going to be a living document that is going grow and be modified, untill it is complete.. ;) | + | Like the rest of the WIKI this is going to be a living document that is going grow and be modified, until it is complete.. ;) |
==== Forum discussions about this topic: ==== | ==== Forum discussions about this topic: ==== | ||
Line 11: | Line 11: | ||
[[http://www.midibox.org/forum/index.php?topic=6480.0| Analog effects, was "Midifiying a sega genesis"]] - it all began here\\ | [[http://www.midibox.org/forum/index.php?topic=6480.0| Analog effects, was "Midifiying a sega genesis"]] - it all began here\\ | ||
[[http://www.midibox.org/forum/index.php?topic=6331.0| Analogue Drum Modules]]\\ | [[http://www.midibox.org/forum/index.php?topic=6331.0| Analogue Drum Modules]]\\ | ||
- | [[http://www.midibox.org/forum/index.php?topic=4065.0| midification of an analog filter]]\\ | + | [[http://midibox.org/forums/topic/4029-midification-of-an-analog-filter| midification of an analog filter]]\\ |
- | [[http://www.midibox.org/forum/index.php?topic=2556.0| Digitally controlled resistors]]\\ | + | [[http://midibox.org/forums/topic/2539-digitally-controlled-resistors| Digitally controlled resistors]]\\ |
- | [[http://www.midibox.org/forum/index.php?topic=6245.0| converting CV to resistance?]]\\ | + | [[http://midibox.org/forums/topic/5815-converting-cv-to-resistance| converting CV to resistance?]]\\ |
[[http://www.midibox.org/forum/index.php?topic=4836.0| Midibox as Switcher advice sought]]\\ | [[http://www.midibox.org/forum/index.php?topic=4836.0| Midibox as Switcher advice sought]]\\ | ||
[[http://www.midibox.org/forum/index.php?topic=7280.0| PGA Audio Mixer Chip projects]]\\ | [[http://www.midibox.org/forum/index.php?topic=7280.0| PGA Audio Mixer Chip projects]]\\ | ||
Line 19: | Line 19: | ||
==== External links and resources: ==== | ==== External links and resources: ==== | ||
- | + | FIXME MOST OF THE LINKS ARE DEAD! | |
- | [[http://en.wikipedia.org/wiki/CV/Gate|CV/Gate]] - start here if you're new to all this stuff. Also links to articles on DIN sync and Roland DCB (wikipedia)\\ | + | here is fixed one: [[http://www.bernacomp.com/elec/og2/og3_echo.html|OG3Echo-Vactrols...]]\\ |
+ | [[http://en.wikipedia.org/wiki/CV/Gate|CV/Gate]] - start here if you're new to all this stuff. Also links to articles on DIN sync and Roland DCB (wikipedia)\\ | ||
[[http://rubidium.dyndns.org/cag/| CAG: Cloned Analog Gear]] - mostly synth, some FX, voltage controlled resistors, ADSR etc. Collection of projects from electronics mags as PDFs\\ | [[http://rubidium.dyndns.org/cag/| CAG: Cloned Analog Gear]] - mostly synth, some FX, voltage controlled resistors, ADSR etc. Collection of projects from electronics mags as PDFs\\ | ||
+ | [[http://www.flickr.com/photos/11165691@N03/tags/|Mike Peake's Schematics]] - lots of good stuff\\ | ||
[[http://yusynth.net/Modular/modular.html| YuSynth Modular]] - personal project site with full schematics, PCB and component layouts, parts list for modern components. Cloned filters from the MiniMoog, Steiner, ARP, EMS; LFOs, envelopes, wavefolder distortion, mixers etc\\ | [[http://yusynth.net/Modular/modular.html| YuSynth Modular]] - personal project site with full schematics, PCB and component layouts, parts list for modern components. Cloned filters from the MiniMoog, Steiner, ARP, EMS; LFOs, envelopes, wavefolder distortion, mixers etc\\ | ||
+ | [[http://www.bridechamber.com/| Bridechamber DIY]] - diy site offering a small&cheap VCR pcb/schematic using vactrols\\ | ||
+ | [[http://highlyliquid.com//| Higly Liquid]] -MIDI Kits, Circuit Bending, Custom Electronic Instruments, checkout the MPA MIDI Decoder; 4 x potentiometer output and 8 x logic output controlled by midi\\ | ||
+ | [[http://www.tomwiltshire.co.uk/sdiy/index.html|VC LFO and ADSR on PIC 16s]] - cloning analogue LFO and ADSR with PICs.\\ | ||
+ | [[http://www.recproaudio.com/diy_pro_audio/index.htm|C A Y O C O S T A]] - schematics, wiring layouts, parts lists, chassis templates, photos and mp3 samples related to building your own classic recording studio equipment\\ | ||
+ | [[http://paia.com/| PAiA]] - Famous maker of reasonably priced kit modulars, filters, rack/desk synths, theremins, MIDI controllers, FX\\ | ||
+ | [[http://www.thatcorp.com/appnotes.html| THAT Corp Application and Design Notes]] - a wealth of schematics\\ | ||
+ | [[http://www.musicfromouterspace.com/analogsynth.php?page=ANALOG| Music From Outer Space]] - synth DIY site with many fully documented designs and PCBs for sale. Home of the famous [[http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/soundlab.html| Sound Lab Mini Synth]]\\ | ||
===== Midifying Pots, Resistors and other Tunable Controls ===== | ===== Midifying Pots, Resistors and other Tunable Controls ===== | ||
- | In practice this means make a circuit that can act as a controllable resistor and replace the original pot or resistor in a circuit. This can be done several ways: | + | In practice this means make a circuit that can act as a controllable resistor and replace the original pot or resistor in a circuit. This can be done several ways: |
- | * [[midiboxfx_-_midifiying_analog_gear#analogvoltage_controlled_resistors||analog]] voltage controlled resistors (VCR) on MIDI to CV converter or AOUT module. | + | * [[midiboxfx_-_midifiying_analog_gear#analogvoltage_controlled_resistors|analog]] voltage controlled resistors (VCR) on MIDI to CV converter or AOUT module. |
* [[midiboxfx_-_midifiying_analog_gear#digital|digital]] digipots (digital potentiometers) or digitally controlled resistors (DCRs), or a resistor ladder network and relays. | * [[midiboxfx_-_midifiying_analog_gear#digital|digital]] digipots (digital potentiometers) or digitally controlled resistors (DCRs), or a resistor ladder network and relays. | ||
- | * [[midiboxfx_-_midifiying_analog_gear#mechanicalmotorized_pots||mechanical]] - coupling analog pots with motorpots on MF module. | + | * [[midiboxfx_-_midifiying_analog_gear#mechanicalmotorized_pots|mechanical]] - coupling analog pots with motorpots on MF module. |
==== Analog: Voltage Controlled Resistors ==== | ==== Analog: Voltage Controlled Resistors ==== | ||
- | The MIDIbox platform already interfaces with the analog world (with the midibox cv and the AOUT_LC module) by converting midi messages to control voltages (for variable values and notes) and gates (for on/off messages). So the first and most important link for MIDIfication has been made. | + | The MIDIbox platform already interfaces with the analog world. The MIDIbox CV and the AOUT_LC module can convert MIDI messages to control voltages for variable values and notes, and to gates for on/off and trigger messages. So the first and most important link for MIDIfication has been made. |
- | Alltough a lot of analog synths/music gear (diy or old school) have implemented voltage control for automation/modulation of basic parameters like pitch (VoltageControlledOscillator), volume (VCAmplifiers) and timbre (VCFilters), this is where it usually stops. However, there are a lot of nice diy designs on the net that would be way more interesting and usable if their parameters could be voltage controlled. | + | |
- | For instance; | + | Although a lot of analog synths and music gear (DIY or old school) have implemented voltage control for automation and modulation of basic parameters like pitch (VCOscillators), volume (VCAmplifiers) and timbre (VCFilters), this is where it usually stops. |
- | * DIY stompbox/guitarfx;distortions, flangers, delays, reverbs etc. | + | However, there are a lot of nice DIY designs on the net that would be way more interesting and usable if their parameters could be voltage controlled. |
+ | For instance: | ||
+ | * DIY stompbox/guitar effects: distortions, flangers, delays, reverbs etc. | ||
* Analog drums (most of the time only have trigger/gate and maybe accent control inputs) | * Analog drums (most of the time only have trigger/gate and maybe accent control inputs) | ||
+ | * Circuit bent gear\\ | ||
- | * Circuit bent gear | ||
- | If you want to “midify" parameters of these circuits the most obvious thing to do is to replace a pot (variable resistor/knob) or a straight resistor with a voltage controlled resistor. | + | If you want to “MIDIfy" parameters of these circuits the most obvious thing to do is to replace a pot (variable resistor/knob) or a straight resistor with a voltage controlled resistor. |
- | There are some hidden advantages here; when make a VCR you can use other cv generators on it too (lfo’s, envelopes, sensors, analog sequencers etc.). It’s also easy so make a small DC mixer for the control voltage so you can have a normal pot that “offsets” the the control voltage. | + | There are some hidden advantages here. When making a VCR you can control it with other CV generators as well, such as LFOs, envelopes, sensors, analog sequencers etc. It’s also easy so make a small DC mixer for the control voltage so you can have a normal pot that “offsets” the the control voltage, or to combine the control voltage from two sources. |
- | The main goal is to get the required resistance range and the response curve right. I’m not aiming to get perfect responses like 1V/Oct for the CV inputs, with most parameters apart from pitch this is unneccesary anyway. | + | The main goal is to get the required resistance range and the response curve right. I’m not aiming to get perfect responses like 1V/Oct for the CV inputs. With most parameters apart from pitch this is unnecessary anyway. |
- | === Option 1; the vactrol === | + | === Option 1: The Vactrol === |
- | The vactrol is in essence a LDR (light dependant resistor) / LED combination in a light proof container; a control voltage can drive the LED, changes its brightness and the intensity of light will vary the resistance of the LDR. | + | The vactrol is in essence a LDR (light dependant resistor) / LED combination in a light proof container. A control voltage can drive the LED, change its brightness and the intensity of light will vary the resistance of the LDR. <sub>would this work with PWM of the LED? DrBunsen</sub> |
- | Circuitry on both sides can be used to scale voltages/resistance/response to a useable range. The relatively long response time doesn’t have to be a bad thing for most applications (when you are sweeping an FX parameter for instance). | + | Circuitry on both sides can be used to scale voltages/resistance/response to a useable range. The relatively long response time <sub>this suggests maybe PWM would work!</sub> doesn’t have to be a bad thing for most applications: for instance, when you are sweeping an FX parameter . |
- | [[http://www.bridechamber.com/|Bridechamber]], a seller of synth modules and kits, intend to offer soon a 1"x2" vactrol based VCR as a kit or prebuilt. The size makes it suitable to directly replace a pot or resistor in circuit. Find it under "PCBs" and email them for more details. | + | [[http://www.bridechamber.com/|Bridechamber]] - a seller of synth modules and kits, intend to offer soon a 1"x2" vactrol based VCR as a kit or prebuilt. The size makes it suitable to directly replace a pot or resistor in circuit. Find it under "PCBs" and email them for more details. |
- | As a starting point for our own designs I (illogik) have taken part of a schematic for a voltage controlled delay from Scott Bernardi [[http://home.comcast.net/~sbernardi/elec/og2/og2_home.html|(og2 diy modular synth)]]. It uses a vactrol to control the delay time. (If you want to build the delay; I’ve made a sketchy (but working!) pcb design (eagle *.brd) for it which I will post later this week). | + | As a starting point for our own designs I (illogik) have taken part of a schematic for a voltage controlled delay from Scott Bernardi - [[http://home.comcast.net/~sbernardi/elec/og2/og2_home.html|og2 diy modular synth]]. It uses a vactrol to control the delay time. |
- | {{http://home.wanadoo.nl/marcel01011/diyfiles/VCR/delayvactrolscl.jpg}} | + | If you want to build the delay, I’ve made a sketchy but working PCB design for it in Eagle *.brd format, which I will post later this week. //any news? DrB// |
- | About the schematic; | + | {{midiboxfx:delayvactrolscl.jpg?300x*}}//Click for full size// |
- | For now these are the resistor values that were in the original design. You should always use a yellow led; LDR’s work best with this colour. This design uses an op-amp which requires a bipolar supply voltage (like +/-12V) but you may have this already for your MIDI to CV converter. RV1 and RV3 are trimpots, although RV1 can be a front-panel pot too for setting the amount of CV input. | + | _About the schematic:_ |
- | === Option 2; the FET === | + | For now these are the resistor values that were in the original design. You should always use a yellow LED; LDR’s work best with this colour. |
+ | This design uses an op-amp which requires a bipolar supply voltage like +/-12V. You may have this already for your MIDI to CV converter. RV1 and RV3 are trimpots, although RV1 can be a front-panel pot too for setting the amount of CV input. | ||
- | This circuit (thanks jaicen) is from [[http://www.hoohahrecords.com/resfreq/index.html| resonant frequency]] (nice diy synth/gear mod site), it’s one of the mods on a Boss DR-110 to making a parameter voltage controlled. | + | === Option 2: the FET === |
- | {{http://home.wanadoo.nl/marcel01011/diyfiles/VCR/FETscl.jpg}} | + | This circuit (thanks jaicen) is from [[http://www.hoohahrecords.com/resfreq/index.html| resonant frequency]] - a nice DIY synth/gear mod site. It’s one of the mods on a Boss DR-110 to make a parameter voltage controlled. |
- | About the schematic; | + | {{midiboxfx:fetscl.jpg?200x*}}//Click for full size// |
- | It’s a really small VCR; transistor/resistor connected to 2 pots. A 100k log pot is OK for the CV-offset pot, manual control pot is linear but has a different value depending on the resistor that needs to be replaced, experiment to find which value sounds best. | + | _About the schematic:_ |
+ | It’s a really small VCR; transistor/resistor connected to 2 pots. A 100k log pot is OK for the CV-offset pot. The manual control pot is linear but has a different value depending on the resistor that needs to be replaced. Experiment to find which value sounds best. | ||
A limitation of this VCR is that one terminal is ground, so the original resistor you want to replace has to have been connected to ground as well. | A limitation of this VCR is that one terminal is ground, so the original resistor you want to replace has to have been connected to ground as well. | ||
- | Some words from Dave Magnuson from Resonant Frequency; | + | Some words from Dave Magnuson from Resonant Frequency: |
//Feel free to use the transistor approach on your site... BUT... I don't | //Feel free to use the transistor approach on your site... BUT... I don't | ||
Line 86: | Line 99: | ||
TR-606 modifications and adapted to work on the DR-110.// | TR-606 modifications and adapted to work on the DR-110.// | ||
- | //Also note: This option is not the best, just a simple one. The linearity | + | //Also note: This option is not the best, just a simple one. The linearity |
of the response is pretty bad, and the range of CV is not ideal.... but it's | of the response is pretty bad, and the range of CV is not ideal.... but it's | ||
cheap and has a very low parts count.// | cheap and has a very low parts count.// | ||
- | //Vactrols work great, although they are slow to turn "off". I'm using these | + | //Vactrols work great, although they are slow to turn "off". I'm using these for some controls in a drum machine that I'm building... I'm using the slow turn off time to create the typical pitch sweep you get with an analog drum. If I pulse the vactrol with a quick trigger (a few milliseconds) the |
- | for some controls in a drum machine that I'm building... I'm using the slow | + | |
- | turn off time to create the typical pitch sweep you get with an analog drum. | + | |
- | If I pulse the vactrol with a quick trigger (a few milliseconds) the | + | |
vactrol's natural decay works well.// | vactrol's natural decay works well.// | ||
Line 100: | Line 110: | ||
There are examples in the datasheet or in the AppNote for the part.// | There are examples in the datasheet or in the AppNote for the part.// | ||
- | From the H11F3 (PHOTO FET OPTOCOUPLER) datasheet; | + | From the H11F3 (PHOTO FET OPTOCOUPLER) datasheet: |
//H11F3 as a remote variable resistor// | //H11F3 as a remote variable resistor// | ||
* //≤100 Ω to ≥ 300 MΩ// | * //≤100 Ω to ≥ 300 MΩ// | ||
* //≥99.9% linearity// | * //≥99.9% linearity// | ||
=== Option 3; the OTA === | === Option 3; the OTA === | ||
The OTA (operational transconductance amplifier) is an IC which is used in many VCA designs. You can use the LM13700, a dual OTA | The OTA (operational transconductance amplifier) is an IC which is used in many VCA designs. You can use the LM13700, a dual OTA | ||
- | This text and the designs are straight out of the LM13700 datasheet; | + | This text and the designs are straight out of the LM13700 datasheet. |
//An OTA may be used to implement a Voltage Controlled Resistor. | //An OTA may be used to implement a Voltage Controlled Resistor. | ||
Line 129: | Line 136: | ||
VCR with one end that must be attached to ground (uses half the IC) | VCR with one end that must be attached to ground (uses half the IC) | ||
- | {{http://home.wanadoo.nl/marcel01011/diyfiles/VCR/OTAsingle2.jpg}} | + | {{midiboxfx:otasingle2.jpg?200x*}}//Click for full size// |
- | “Floating" VCR; both sides of VCR are free | + | “Floating" VCR: both sides of VCR are free |
- | {{http://home.wanadoo.nl/marcel01011/diyfiles/VCR/OTAdouble2.jpg}} | + | {{midiboxfx:otadouble2.jpg?300x*}}//Click for full size// |
- | //A floating VCR where each “end” of the “resistor” may be at any voltage within the | + | //A floating VCR where each “end” of the “resistor” may be at any voltage within the output voltage range of the LM13700.// |
- | output voltage range of the LM13700.// | + | |
- | About the schematics | + | _About the schematic:_ |
Hmm, I (illogik) can’t say I really understand all this, but maybe that’s not necessary; I will build the circuits and do some experimenting. Vc is the CV input; there can be some opamp mixers befor this point to do the scaling. | Hmm, I (illogik) can’t say I really understand all this, but maybe that’s not necessary; I will build the circuits and do some experimenting. Vc is the CV input; there can be some opamp mixers befor this point to do the scaling. | ||
- | [[http://www.example.com|External Link]] | ||
==== Digital: Digipots ==== | ==== Digital: Digipots ==== | ||
+ | [[http://www.analog.com/en/subCat/0,2879,761%255F797%255F0%255F%255F0%255F,00.html|Digital Potentiometers: Description]] - from Analogue Devices. | ||
+ | //A **digital potentiometer** adjusts and trims electronic circuits similar to variable resistors, rheostats and mechanical potentiometers. Sometimes called **digital POT, RDAC**, or **digipot**, these devices can be used to calibrate or dynamically control system parameters.// | ||
+ | This method means desoldering and replacing existing pots or resistors with digitally controlled variants, or switching between digitally controlled and physically controlled resistors. Switches could be CMOS controlled switches, controlled by pulses from the DOUT module. | ||
- | Digipots/DCR's, CMOS - This method means desoldering and replacing existing pots or resistors with digitally controlled variants, or switching between digitally controlled and physically controlled resistors, | + | It seems a fairly easy solution at first and digipots are not quite as expensive as motorfaders, but as we know, the digital signals can make things a bit messy. |
- | Switches would be CMOS controlled switches, controlled by pulses from the DOUT module. | + | |
- | It seems a fairly easy solution at first and digipots are not quite so expensive as motorfaders, but as we know, the digital signals can make things a bit messy. | + | There are concerns about noise from the digital control bus leaking into the audio signal, but that might be worked around by heavy shielding and perhaps a separate ground plane. The separate ground could be tricky to implement though, and that implementation would vary greatly from one device to another, increasing support requirements. |
- | There are concerns about noise from the digital control buss leaking into the audio signal, but that might be worked around by heavy shielding and perhaps a separate ground plane. The separate ground could be tricky to implement though, and that implementation would vary greatly from one device to another, increasing support requirements. | + | |
One upside with this is that little additional hardware is required. | One upside with this is that little additional hardware is required. | ||
- | Another possible method is to create a resistor ladder network cotrolled by a set of relay ICs. This method has been used in DIY hifi projects as a low-noise, high accuracy volume control. | + | [[http://www.analog.com/en/content/0,2886,761%255F797%255F19160,00.html|Frequently Asked Questions: Digital Potentiometers]] - from Analog Devices\\ |
+ | [[http://www.analog.com/en/subCat/0,2879,761%255F797%255F0%255F%255F0%255F,00.html|Table Of Products]] - AD again\\ | ||
+ | [[http://www.maxim-ic.com/DigitalPotentiometers.cfm|Maxim's range]]\\ | ||
+ | Another possible method is to create a resistor ladder network controlled by a set of relay ICs. This method has been used in high-end audio, both DIY and commercial as a low-noise, high accuracy volume control. It is also known as an R2R attenuator. | ||
+ | Resistor ladders have as many resistors as you wish for bit accuracy. IE an 8 bit resolution requires 8 resistors, 16 bits - 16 resistors etc. The AOUT LC module uses a resistor ladder. | ||
+ | The largest resistor has half the value of the resistor you're substituting for, the next one half of that again, and so on. The sum of all the resistors is equal to the substituted one. | ||
+ | The resistors are arranged serially, with bypass (zero resistance) paths switched by the relays. Each bit of the digital value switches on or off one relay, and thus bypasses (or not) one resistor. Thus you can dial up any resistance, in steps equal to the value of the smallest resistor. The relay ICs could be controlled by a DOUT. | ||
+ | Where accuracy is important (ie pitch) this technique requires low tolerance or hand matched resistors, at least for the most significant bits. 5% variance would not be acceptable for the resistor making up half of your overall value. | ||
+ | An advantage of this method is substituting for resistors in-circuit where a digital resistor of matching value is not available, or where voltages and currents would be higher than they are rated for. | ||
+ | ==== Digital: Digital capacitors ==== | ||
+ | I'll let [[http://afrotechmods.com/cheap/capacitor/digitalcapacitor.htm| Afroman]] do the talking, but a couple of stolen JPEGs should give you the general idea. He extends the principle to the construction of digitally controlled LC filters and oscillators. | ||
+ | {{http://afrotechmods.com/cheap/capacitor/TristateDiagram.gif?600}}{{http://afrotechmods.com/cheap/capacitor/2bitdigicap.gif}}Repeat to desired bitwidth\\ | ||
- | Resistor ladders have as many resistors as you wish for bit accuracy ie an 8 bit resolution requires 8 resistors, 16 bits = 16 resistors etc. The AOUT_LC module uses a resistor ladder. | ||
- | The largest resistor has half the value of the resistor you're substituting for, the next one half of that again, and so on. The resistors are arranged serially, with bypass (zero resistance) paths switched by the relays. By switching on and off the paths to | ||
- | each resistor with the relays, you can "dial up" the resistance value you require. The relay ICs could be controlled by a DOUT. | ||
- | This technique requires low tolerance or hand matched resistors, at least for the most significant bits. 5% variance would not be acceptable for the resistor making up half of your overall value. | ||
- | An advantage of this method is substituting for resistors in-circuit where a digital resistor of matching value is not available. | ||
==== Mechanical: Motorized pots ==== | ==== Mechanical: Motorized pots ==== | ||
+ | Motorpots attached to analog pots - This way uses motorized pots or rotary motorfaders (depending on what you want to call them) to move analog pots like a servo. | ||
- | Motorpots attached to analog pots - This way uses motorised pots or rotary motorfaders (depending on what you want to call them) to move analog pots like an abolute servo. | + | It is completely noiseless because the MB and FX circuits are electrically isolated and only coupled mechanically, but could be expensive, as motorpots aren't cheap, and it could also be harder to do mechanically. This way would mean that the price would vary depending on how many knobs you need but we would need the additional MF module for this. |
- | It is completely noiseless because the MB and FX circuits are electrically isolated and only coupled mechanically, but could be expensive, as motorpots aren't cheap, and it could also be harder to do mechanically. This way would mean that the price would vary depending on how many knobs you need but we would need the additional MF module for this. | + | |
- | It would also mean that if you were midifying existing gear, you could keep the existing controls in place, so the MIDIBox wouldn't have to be active to use the gear - this is of course assuming that there is room inside the case of your gear to add the motorpots. This method would also introduce support issues with MBFX users coming here for mechanical support on how to link up their pots etc... Also Implementing switches/buttons with this method would probably involve either analog or digital solutions which might defeat the bonus of total electrical isolation, unless using a servo to flick the switch... | + | |
- | ===== Midifying Switches/Signal routing ===== | + | It would also mean that if you were midifying existing gear, you could keep the existing controls in place, so the MIDIBox wouldn't have to be active to use the gear - this is of course assuming that there is room inside the case of your gear to add the motorpots. |
+ | This method would also introduce support issues with MBFX users coming here for mechanical support on how to link up their pots etc... | ||
- | - Simple method with cmos-switch from René Schmitz's synthdiy site: | + | Also implementing switches/buttons with this method would probably involve either analog or digital solutions which might defeat the bonus of total electrical isolation, unless using a servo to flick the switch... |
- | [[http://www.uni-bonn.de/~uzs159/switch.html]] | + | //Yeah! MIDIbox robotic synth players!// |
- | - And this ic from Analog Devices could make a nice MBPatchMatrix ;) | + | ===== Midifying Switches/Signal routing ===== |
+ | [[http://www.analogindustries.com/blog/entry.jsp?msgid=1175469917842|Simple method with transistors]] from analogindustries blog\\ | ||
+ | [[http://www.uni-bonn.de/~uzs159/switch.html|Simple method with CMOS switch]] from René Schmitz's synthdiy site\\ | ||
- | [[http://www.analog.com/en/prod/0,,768_832_AD8113%2C00.html]] | + | [[http://www.analog.com/en/prod/0,,768_832_AD8113%2C00.html|This IC from Analog Devices]] could make a nice MBPatchMatrix ;) |
//**AD8113 - Audio/Video 60MHz 16 x 16 Crosspoint Switch**// | //**AD8113 - Audio/Video 60MHz 16 x 16 Crosspoint Switch**// | ||
Line 194: | Line 218: | ||
The channel switching is performed via a serial digital control (which can accommodate daisy-chaining of several devices) or via a parallel control, allowing updating of an individual output without reprogramming the entire array.// | The channel switching is performed via a serial digital control (which can accommodate daisy-chaining of several devices) or via a parallel control, allowing updating of an individual output without reprogramming the entire array.// | ||
- | it's quite expenisve but if this works it will open up a lot of possibilities | + | it's quite expensive but if this works it will open up a lot of possibilities |
- | **ANYONE WITH SUGGESTIONS, IDEAS, QUESTIONS OR WHATEVER CONCERNING THE CREATION OF DIGITAL CONTROLLED ANALOG HYBRID MONSTER MACHINES: CONTACT/PM ME(ILLOGIK ON MIDIBOXFORUM)! I LOVE TALKING ABOUOT THIS STUFF, AND WHO KNOWS WHAT OUR FORCES COMBINED COULD DO!** | + | **ANYONE WITH SUGGESTIONS, IDEAS, QUESTIONS OR WHATEVER CONCERNING THE CREATION OF DIGITAL CONTROLLED ANALOG HYBRID MONSTER MACHINES: CONTACT/PM ME(ILLOGIK ON MIDIBOXFORUM)! I LOVE TALKING ABOUT THIS STUFF, AND WHO KNOWS WHAT OUR FORCES COMBINED COULD DO!** |
