midiboxfx_-_midifiying_analog_gear [2008/07/11 09:33] dj3nk moved audio matrix chip info to certain userproject |
midiboxfx_-_midifiying_analog_gear [2011/08/05 12:03] shanessarichardson |
Line 206: | Line 206: | ||
[[http://www.analogindustries.com/blog/entry.jsp?msgid=1175469917842|Simple method with transistors]] from analogindustries blog\\ | [[http://www.analogindustries.com/blog/entry.jsp?msgid=1175469917842|Simple method with transistors]] from analogindustries blog\\ | ||
[[http://www.uni-bonn.de/~uzs159/switch.html|Simple method with CMOS switch]] from René Schmitz's synthdiy site\\ | [[http://www.uni-bonn.de/~uzs159/switch.html|Simple method with CMOS switch]] from René Schmitz's synthdiy site\\ | ||
+ | [[http://www.analog.com/en/prod/0,,768_832_AD8113%2C00.html|This IC from Analog Devices]] could make a nice MBPatchMatrix ;) | ||
+ | //**AD8113 - Audio/Video 60MHz 16 x 16 Crosspoint Switch**// | ||
+ | //The AD8113 is a fully buffered crosspoint switch matrix that operates on ±12V for Audio applications and ±5V for Video applications. It offers a -3dB signal bandwidth greater than 60MHz and channel switch times of less than 60ns with 0.1% settling for use in both analog and digital audio. The AD8113 operated at 20kHz has crosstalk performance of -83dB and isolation of 90dB. In addition, ground/power pins surround all inputs and outputs to provide extra shielding for operation in the most demanding audio routing applications. The differential gain and differential phase of better than 0.1% and 0.1°, respectively, along with 0.1dB flatness out to 10MHz make the AD8113 suitable for many video applications. | ||
+ | The AD8113 includes 16 independent output buffers that can be placed into a disabled state for paralleling crosspoint outputs so that off channel loading is minimized. The AD8113 has a gain of +2. It operates on voltage supplies of ±5V or ±12V while consuming only 34mA or 31mA of current, respectively. | ||
+ | The channel switching is performed via a serial digital control (which can accommodate daisy-chaining of several devices) or via a parallel control, allowing updating of an individual output without reprogramming the entire array.// | ||
+ | it's quite expenisve but if this works it will open up a lot of possibilities | ||
+ | **ANYONE WITH SUGGESTIONS, IDEAS, QUESTIONS OR WHATEVER CONCERNING THE CREATION OF DIGITAL CONTROLLED ANALOG HYBRID MONSTER MACHINES: CONTACT/PM ME(ILLOGIK ON MIDIBOXFORUM)! I LOVE TALKING ABOUOT THIS STUFF, AND WHO KNOWS WHAT OUR FORCES COMBINED COULD DO!** | ||
+ | [[http://customcollegeessays.com/index.php|college essay]] |
