====== MBHP_OPL3 module modifications, the 5V option ====== The [[http://www.ucapps.de/mbhp_opl3.html|OPL3]] module originally has three TL074 op-amps, and a circuit that needs +/-12V bipolar power supply. In Wilba and nILS sammichFM, they use two OPA4348 rail-to-rail op-amps, that can be powered by 5V. Sauraen suggested another 5V rail-to rail op-amp, the MCP6004, which is pin compatible with the TL074, and a way to modify the OPL3 module to use these.[[http://midibox.org/forums/topic/18492-mbfm-5v-option/]] - Replace R5,R7,R10 and R13 with jumpers\\ - Bridge IC6 pads 1&3, 5&7, 8&10 and 12&14\\ - Leave out:\\ IC6\\ R4, R6, R8, R9, R11, R12, R14, R15\\ C15, C16, C19, C20, C23-C30\\ - Bridge C20 pads (to supply Ground for the op-amps)\\ - Leave out bridges to IC6\\ - Use MCP6004 for IC3 and IC5\\ - Supply 5V to the +12V pin, and Ground to Ground\\ This way the second buffering stage is left out. In the sammichFM, nILS designed a separate dedicated 5V supply for the DACs (YAC512) and the op-amps.\\ To modify the OPL3 module for this approach:\\ - Cut the trace between the 5V pin of the Oscillator and the DAC\\ - Leave out the middle horizontal bridge from IC1\\ - Connect the right pad of this bridge to the 5V pin in the middle of the board with a jumper\\ - Connect the left pad of this bridge to the 5V pin of the Oscillator with a jumper\\ - Two separate 5V voltage regulators, IN pins connected through a ferrite bead\\ - One 5V source to Core and J1 of OPL3 module\\ - The other 5V source to J3 of OPL3 module\\ - Ground ONLY to J3!\\ Tips:\\ - Starlike wiring (Ground from PSU to each module + Audio outputs)\\ I can vouch for these mods :)\\ My MIDIbox FM V1 has hardly any noise, and it has enough gain. {{:opl3.jpg?direct|}}
