pedal_box
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
pedal_box [2010/04/13 07:53]
durisian
pedal_box [2014/01/19 10:10]
shuriken
Line 169: Line 169:
Line 177: Line 192:
 [[http://​svnmios.midibox.org/​filedetails.php?​repname=svn.mios&​path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Fdocs%2FPB_Manual.pdf|The Complete Usage Manual]] [[http://​svnmios.midibox.org/​filedetails.php?​repname=svn.mios&​path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Fdocs%2FPB_Manual.pdf|The Complete Usage Manual]]
-Help can be found in the [[http://www.midibox.org/​forum/index.php/topic,​9770.30.html ​| Pedal Box forum thread ]]+Help can be found in the [[http://​midibox.org/​forums/topic/9081-the-pedal-box-and-pedal-board-thread ​| Pedal Box forum thread ]]
Line 397: Line 412:
 <box 46% left round bluedark|Device Bankstick Downloads>​ <box 46% left round bluedark|Device Bankstick Downloads>​
-[[http://​svnmios.midibox.org/​filedetails.php?​repname=svn.mios&​path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2FDevice_Config_Files%2FV-Amp%2FV-Amp.zip|Behringer V-Amp Series]] +{{:mcrozier:v-amp.zip|Behringer V-Amp Series}}
 </​box>​ \\  </​box>​ \\
 <box 46% left round|PC Editor> ​ <box 46% left round|PC Editor> ​
-[[http://​svnmios.midibox.org/​filedetails.php?​repname=svn.mios&​path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Feditor%2Fv2%2FPBEditor2.zip|Pedal Board Editor 2 v1.0]] \\ +{{:mcrozier:​pbeditor2.zip|Pedal Board Editor 2 v1.0}} \\
 Please note the editor requires a minimum of WinXP with .Net 3.5 \\  Please note the editor requires a minimum of WinXP with .Net 3.5 \\
 </​box>​ </​box>​
- +<box 98% round|Docs>​
-[[http://​svnmios.midibox.org/​filedetails.php?​repname=svn.mios&​path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Fdocs%2FPB_Manual.pdf|The Complete Usage Manual]]+{{:mcrozier:​pb_manual.pdf|The Complete Usage Manual}}</​box>​
Line 436: Line 451:
-Please report bugs in the [[http://www.midibox.org/​forum/index.php/topic,​9770.30.html ​| Pedal Box forum thread ]]+Please report bugs in the [[http://​midibox.org/​forums/topic/9081-the-pedal-box-and-pedal-board-thread ​| Pedal Box forum thread ]]
Line 595: Line 610:
 The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\  The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\
 The second digit (ten'​s) will be automatically assigned to the next shift register. The second digit (ten'​s) will be automatically assigned to the next shift register.
 +If only 1 digit is used, and bank goes higher than 9. The dot will light up to let you know that '​0'​ is actually 10, '​1'​ is actually 11, etc \\
 In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h.
Line 623: Line 640:
 ==== Connection Overview ==== ==== Connection Overview ====
 {{http://​www.durisian.com/​midibox/​PB/​images/​pbd_din_dout_connections.jpg}} ​ {{http://​www.durisian.com/​midibox/​PB/​images/​pbd_din_dout_connections.jpg}} ​
 +**Please Note:** Default connections have changed since 2.6. The default has only one digit connected to SR 5. With bank and PedalSwap footswitches and LED's attched to SR 4
 Pedal Board Test Bench \\  Pedal Board Test Bench \\
Line 635: Line 655:
 I only built Pedal Box, so I use the Behringer FCV100 Foot Pedal in CV mode. But here's some links that came up on the forum. I only built Pedal Box, so I use the Behringer FCV100 Foot Pedal in CV mode. But here's some links that came up on the forum.
-  * [[http://​www.banzaieffects.com/​Pushbutton-Footswitches-Momentary-c-333.html ​| Banzai Effects]] stock a good range of momentary footswitches - perfect for this project+  * [[http://​www.banzaimusic.com/​Pushbutton-Footswitches-Momentary | Banzai Effects]] stock a good range of momentary footswitches - perfect for this project
   * [[http://​www.smallbearelec.com/​|Small Bear Electronics]] Specializes in DIY guitar sound effects   * [[http://​www.smallbearelec.com/​|Small Bear Electronics]] Specializes in DIY guitar sound effects
   * stryd_one offered this google search for momentary footswitches. [[http://​www.google.com.au/​search?​safe=off&​q=momentary+SPST+footswitch]]   * stryd_one offered this google search for momentary footswitches. [[http://​www.google.com.au/​search?​safe=off&​q=momentary+SPST+footswitch]]
Line 666: Line 686:
 {{mcrozier:​pedal_board_max.jpg}} ​ \\  {{mcrozier:​pedal_board_max.jpg}} ​ \\
 You know you want to build it! You know you want to build it!
pedal_box.txt · Last modified: 2014/01/19 10:10 by shuriken
