pinheader
Pinheader
A pinheader is a basic connector to plug things on your PCB without having them soldered. It can be single or dual row (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm. A pin header is designed to be splitted that you can have only the number of pins required to solder.
pinheader.1465322886.txt.gz · Last modified: 2016/06/07 18:08 by psykhaze
