resistor
Resistor
Introduction
A resistor is an electrical or electronic component that resists the flow of electrons in a circuit.
There are several types of resistors including carbon, ceramic, fixed wirewound, variable wirewound, stationary adjustable wirewound and forms of integrated circuits.
How much a resistor impedes the current flow is called resistance and is measured in ohms. Most resistors have a fixed value as to how much resistance they will display. Wattage, qualities and tolerance values vary according to needs.
MIDIbox related
Most of the resistors used in the MBHP hardware platform are 1/4W 5% tolerance
Put some refs values used in MBHP Boards
resistor.1465302454.txt.gz · Last modified: 2016/06/07 12:27 by psykhaze
