The discussion thread where you can read the latest info and post questions about sammichSID kits is here.
sammichSID was designed to be the “no excuses” MIDIbox SID synthesizer kit - i.e. for all those people who want a MIDIbox SID but consider building it with modules too time-consuming, too newbie-unfriendly and/or too hard to design and construct a control surface, and where MB-6582 is too expensive, too daunting and/or too hard to source all the parts.
sammichSID therefore has the following design constraints/features, which support each other:
MIDIbox SID Synthesizer V2 features
Buying a kit
sammichSID was planned from the start to be available as a complete kit, so all the hard work of sourcing parts, checking for fit, and refining the design has been done already.
Kits will be packed and sold in batches of 25 or 50.
If you want to order now, just email your details (NOT MONEY!) to: Jason.S.Williams@gmail.com
Include your MIDIbox username so I know who I'm talking to!
“Pre-order” just means I collect your email address, and I reserve a kit for you.
There is no commitment to buy, you can cancel or wait for another batch with no bad karma!
When the batch is ready to be prepared, I'll email people to get confirmation and then send out PayPal invoices. That will happen while I order and collect all the parts and put them into kit boxes.
I do not recommend getting a kit unless you already have SIDs, they are very hard to find now on eBay or anywhere else.
Prices as of 2012-01-16: (actual payment will be in AUD with 3.5% PayPal fee added)
Cases are available in matte black or Arctic Ice (semi-transludent, matte white). Scratch and fingerprint resistant. The default kit contains an FSTN negative yellow-green backlight LCD and green LEDs, as show above.
LCD, LEDs and case are optional, if you want to source your own. I will deduct cost of parts not included.
ALSO Let me know if you're an Aussie, I can help you with a suitable plugpack and give you custom postage cost.
You can find v1.0 of the build guide here (zipped 6MB PDF):
sammichSID_Build_Guide_v1_0.zip
(I zipped it so you would be forced to download it and not view it in your browser)
Have a read now while you await your kit, you might want to acquire some things before it arrives, like acrylic paint, brush, heatsinking compound, solder…
If your buttons and/or LEDs aren't working properly this app might help you find the problem.
Here are the PCB layouts in PDF format, for troubleshooting purposes. Note the base PCB has ground plane removed, i.e. pins on the ground plane will be shown without any tracks connected to them, but you can tell on the PCB that they are connected to the ground plane.
Here is a place for people to add links to suitable power supplies.
Jameco: 12VDC 1A Linear Regulated Wall-Wart
(Jameco also offers 500mA if you are not using a high power LCD and know you won't pass that. Since the above is regulated, buying the 1A will work just fine - it's just a few bucks more than the 500mA)
USPS 600 or 1000 Power Supply from Conrad.
