The datawheel and 16 Knobs
The datawheel and 16 Knobs are caps, which should plugged on the 17 rotary encoders.
LTC-Modul
The LTC-Modul is optional and for MIDI IN, 2xMIDI OUT and MIDI THRU Commands or MIDI-TO-COM Mode It's not necessary for a complete SEQ-Box.
9V PSU
With a special circuit, it should be able to use the 9V PSU from FLOPPY 1541-II.
Bankstick EEPROM
For SEQ the maximum use are 2x 24LC256 or 1x 24LC512. The couple circuit should be built up like description under the menu-point “Bankstick”. Details under http://www.ucapps.de/midibox_seq_options.html
LCD Connection
There is a schamatic of how to connect 2 LCDs: http://www.ucapps.de/mbhp_lcd.html
Methods you may choose to do that (IDC cable, ribbon cable configuration, etc) are discussed in this forum thread.
