switch [2016/06/07 13:25] psykhaze [Introduction] |
switch [2016/07/10 15:04] psykhaze [Matrix Design] |
Line 1: | Line 1: | ||
====== Switch ====== | ====== Switch ====== | ||
- | {{ ::neonking:switches.jpg?direct |}} | ||
Line 7: | Line 5: | ||
A switch is a small lever or button. It's an electrical device having at least **two states**, ON (the closed state) or OFF (the open state). | A switch is a small lever or button. It's an electrical device having at least **two states**, ON (the closed state) or OFF (the open state). | ||
- | Ideally, a switch device has zero impedance when closed and infinite impedance when open. The switches on the back of printers and on expansion boards are called DIP switches. A switch that has just two positions is called a toggle switch.A "click switch" is called SPST switch. | + | Ideally, a switch device has zero impedance when closed and infinite impedance when open. The switches on the back of printers and on expansion boards are called DIP switches. |
+ | A switch that has just two positions is called a toggle switch.A "click switch" is called SPST switch. | ||
+ | {{ ::neonking:switches.jpg?direct |}} | ||
+ | ===== Some Refs? ===== | ||
+ | There is thousands of switches, describing them here would be impossible. | ||
+ | You should have a look to <wrap info>[[parts_faq#what_kind_of_switches_do_i_need|Switch Choosing Guide]]</wrap> | ||
+ | ===== DIN Connection ===== | ||
+ | {{ :neonking:encoder-switch-din.jpg?direct&600 |}} | ||
+ | ==== Matrix Design ==== | ||
+ | {{ :neonking:switchmatrix.jpg?direct&800 |}} |
