switch
Switch
Introduction
A switch is a small lever or button. It's an electrical device having at least two states, ON (the closed state) or OFF (the open state).
Ideally, a switch device has zero impedance when closed and infinite impedance when open. The switches on the back of printers and on expansion boards are called DIP switches.
A switch that has just two positions is called a toggle switch.A “click switch” is called SPST switch.
Some Refs?
There is thousands of switches, describing them here would be impossible.
You should have a look to Switch Choosing Guide
switch.1465915594.txt.gz · Last modified: 2016/06/14 14:46 by psykhaze
