variable_resistor
An adjustable resistor; they can normally be set to give anything from zero resistance to whatever is the maximum design value. Most have three pins so that they can also be used as a voltage divider. Also known as potentiometer or pot.
variable_resistor.1315465552.txt.gz · Last modified: 2011/09/08 07:05 by oliverjones
