wcore
wCoreF4
Introduction
This is a cross-grade of the STM32F4 Core based on the Core407v breakout board from Waveshare. There are other versions of breakouts, but the Waveshare one seems quite a reputable source with decent distribution and documentation.
Pros
  • Slightly smaller footprint
  • (Almost) all connectors on same face
  • Proper USB A and B ports
  • Footswitch/gate 3.5mm jack
  • Hardware host/slave switch
  • LEDs on the panel
  • Reset button on the panel
  • User button on header
  • More mounting options available (e.g. panel mount including USB)
  • 1A 3v3 regulator
  • Possibility for external Vref (for AIN)
Cons
  • Similar height to Disco version (could cut off headers etc.)
  • Lacks ST-LINK and requires a (cheap) programmer or a Discovery module
  • No mounting holes on MCU breakout
  • Requires SMT soldering (wide pitch)
Sub parts
The Core is split over three PCBs:
The MIDI interfaces were also redesigned:
Build instructions are found on the appropriate pages.
MCU module
The actual MCU module is available from several sources:
Burning the bootloader
The MCU module has a USB port, but direct programming would only be possible with a USB-UART programmer. It would also require a different bootloader protocol. Instead, we make use of ST-LINK-like functionality. The MCU module has a typical JTAG header and these pins are also available on the two 2*25 header rows. So even if the header had to be removed for space reasons, it should always be possible to re-flash the MCU.
These are readily available from eBay and other sellers for typically <$10. You only require one programmer to flash as many modules as needed.
Option 2: use a Discovery module
The Discovery module (even if connected to a MIDIbox Core) can be used for programming.
License
wcore.1505050092.txt.gz · Last modified: 2017/09/10 13:28 by latigid_on
