wCoreF4
Introduction
This is a cross-grade of the STM32F4 Core based on the Core407v breakout board from Waveshare. There are other versions of MCU breakouts, but the Waveshare one seems quite a reputable source with decent distribution and documentation.
Pros
- Slightly smaller footprint
- (Almost) all connectors on same face
- Proper USB A and B ports
- Footswitch/gate 3.5mm jack
- Hardware host/slave switch
- LEDs on the panel
- Reset button on the panel
- User button on header
- More mounting options available (e.g. panel mount including USB)
- 1A 3v3 regulator
- Possibility for external Vref (for AIN)
Cons
- Similar height to Disco version (could cut off headers etc.)
- Lacks ST-LINK and requires a (cheap) programmer or a Discovery module
- No mounting holes on MCU breakout
- Requires SMT soldering (wide pitch)
Sub parts
The Core is split over three PCBs:
The MIDI interfaces were also redesigned:
Build instructions are found on the appropriate pages.
MCU module
The actual MCU module is available from several sources:
Burning the bootloader
The MCU module has a USB port, but direct programming would only be possible with a USB-UART programmer. It would also require a different bootloader protocol. Instead, we make use of SWD functionality. The MCU module has a typical JTAG/SWD header and these pins are also available on the two 2*25 header rows.
Option 1: ST-LINK clone
These are readily available from eBay and other sellers for typically <$10. You only require one programmer to flash as many modules as needed.
Option 2: use a Discovery module
The Discovery module (even if connected to a MIDIbox Core) can be used for programming. To do so, remove the two CN3 jumpers labelled ST-LINK/DISCOVERY. This disconnects the SWD interface from the STM32F4 MCU on the Discovery board:
Flashing over SWD
The following five connections should be made with DuPont cables:
- 3v3
- 0V/ground
- DIO
- CLK
- RESET
After that, follow the instructions for the initial flash of a Discovery module.
If the JTAG/SWD header of the 407v board had to be removed and the MCU required re-flashing, it's possible to do so using the named pins on the 2*25 header.
License
