wikify:template:project
** STILL INCOMPLETE ** =====Intro===== All about it, what it does and blah =====Features===== List 'em =====Skills / Equipment Required===== * [[:mbhp:preparation | Preparation]] * [[:soldering]] =====Harware===== ====What modules do I need?==== Adjust List as required: * [[mbhp:module:core | Core Module]] * [[mbhp:module:core32 | Core32 Module]] * [[mbhp:module:lcd | LCD Module]] * [[mbhp:module:bankstick | Bankstick Module]] * [[mbhp:module:ltc | LTC Module]] * [[mbhp:module:din | DIN Module]] * [[mbhp:module:dout | DOUT Module]] * [[mbhp:module:ain | AIN Module]] * [[mbhp:module:aout | AOUT Module]] * [[mbhp:module:aout_ng | AOUT_NG Module]] * [[mbhp:module:aout_lc | AOUT_LC Module]] * [[mbhp:module:shx8 | SHX8 Module]] * [[mbhp:module:sid | SID Module]] * [[mbhp:module:opl3 | OPL3 Module]] * [[mbhp:module:iic_midi | IIC Midi Module]] * [[mbhp:module:iic_speakjet | IIC Speakjet Module]] * + Any custom modules (create link in your projects name space or ':mbhp:module:<you_module>" ====List of parts==== list of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hool them up - links [[:parts | Where to buy Parts]] ====Connections==== Connection diagrams - links if needed (create in you projects namespace ==== Enclosure / Case ==== Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs === Enclosure References === [[:contructing_enclosures]] =====Software===== ==== Setting Up ==== PIC's must be setup with MIOS bootstrap Loader and MIOS before an application can be uploaded. \\ If you purchased you PIC from SmashTV or Mike's PCB Shop these will already installed. We recommend you read the following before you continue: * [[:mios:setting_up | Setting up PIC's and your PC]] * [[http://www.ucapps.de/mios_bootstrap_newbies.html | Burning Bootloader]] * [[:mios:core_toolchain | Core Tools]] * [[:mios:software_tools | Additional tools]] ==== Download ==== links ==== Setup Instructions ==== up to you =====Extra===== [[usage manual]] + anything else
wikify/template/project.1227618486.txt.gz · Last modified: 2008/11/25 13:08 by stryd_one
