General Informations
A DOUT module is a digital output module, usually used to drive LEDs with a Midibox.
Note that hardware pin's will be counted D7 - D0 / O7 - O0 / QH - QA. In contrast, pins for DIN modules will be counted D0 - D7.
Refer the DIN & DOUT Pintable to see the relation between software pin numbers and hardware pins.
Connection to Core Module
Check the version of your Boards; if you’re using SmashTV’s Core that’s equipped with double rows, you can build a split-cable to connect J8/J9 to a DIN and a DOUT:
dout_module.txt · Last modified: 2008/11/24 05:44 by this
Recent changes RSS feed Creative Commons License Donate Powered by PHP Valid XHTML 1.0 Valid CSS Driven by DokuWiki
