Velocity converter
http://www.midibox.org/forum/index.php?topic=8585.0;topicseen
The converter is able to transorm a velocity value of an incoming midi message into another value. In this way you are able to change the velocity curve for your MIDI keyboard.
There is a freeware software that allow you to change velocity curve : Midi velocity curve changer (Trombettworks Software) http://www.trombettworks.com/velocity.php
A first MBHP version
This first version just forward notes with a added “gain” (from 0 to 64).
The gain is set with a 10k pot on the AIN INPUT 0. (dont forget to set unused analog inputs to ground)
velocity_converter_v0.1.zip
A LCD Screen is not needed, but allow to see the input/ouput velocity values.
The Version 0.2 :
They are 16 Preset curves. Moving the pot From min-max select the desired velocity curve.
Curves must be tuned to your needs. (No editor yet)
Curves are separated into distinct files for user comfort : curve1.c, curve2.c, …, curve16.c
velocity_converter_v0.2.zip
also check : http://jambonbill.free.fr/Velocity_converter/ – bill
velocity_converter.txt · Last modified: 2007/11/17 14:58 (external edit)
Recent changes RSS feed Creative Commons License Donate Powered by PHP Valid XHTML 1.0 Valid CSS Driven by DokuWiki
