MIOS32_BOARD
Defines
#define J5_NUM_PINS   0
#define J10_NUM_PINS   0
#define J28_NUM_PINS   0
#define J15_AVAILABLE   0
Functions
s32 MIOS32_BOARD_Init (u32 mode)
s32 MIOS32_BOARD_LED_Init (u32 leds)
s32 MIOS32_BOARD_LED_Set (u32 leds, u32 value)
u32 MIOS32_BOARD_LED_Get (void)
s32 MIOS32_BOARD_J5_PinInit (u8 pin, mios32_board_pin_mode_t mode)
s32 MIOS32_BOARD_J5_Set (u16 value)
s32 MIOS32_BOARD_J5_PinSet (u8 pin, u8 value)
s32 MIOS32_BOARD_J5_Get (void)
s32 MIOS32_BOARD_J5_PinGet (u8 pin)
s32 MIOS32_BOARD_J10_PinInit (u8 pin, mios32_board_pin_mode_t mode)
s32 MIOS32_BOARD_J10_Set (u16 value)
s32 MIOS32_BOARD_J10_PinSet (u8 pin, u8 value)
s32 MIOS32_BOARD_J10_Get (void)
s32 MIOS32_BOARD_J10_PinGet (u8 pin)
s32 MIOS32_BOARD_J28_PinInit (u8 pin, mios32_board_pin_mode_t mode)
s32 MIOS32_BOARD_J28_Set (u16 value)
s32 MIOS32_BOARD_J28_PinSet (u8 pin, u8 value)
s32 MIOS32_BOARD_J28_Get (void)
s32 MIOS32_BOARD_J28_PinGet (u8 pin)
s32 MIOS32_BOARD_J15_PortInit (u32 mode)
s32 MIOS32_BOARD_J15_DataSet (u8 data)
s32 MIOS32_BOARD_J15_SerDataShift (u8 data)
s32 MIOS32_BOARD_J15_RS_Set (u8 rs)
s32 MIOS32_BOARD_J15_RW_Set (u8 rw)
s32 MIOS32_BOARD_J15_E_Set (u8 lcd, u8 e)
s32 MIOS32_BOARD_J15_PollUnbusy (u8 lcd, u32 time_out)
s32 MIOS32_BOARD_DAC_PinInit (u8 chn, u8 enable)
s32 MIOS32_BOARD_DAC_PinSet (u8 chn, u16 value)
Detailed Description
Development Board specific functions for MIOS32
Define Documentation
Function Documentation
s32 MIOS32_BOARD_DAC_PinInit ( u8  chn,
u8  enable
This function enables or disables one of the two DAC channels provided by STM32F103RE (and not by STM32F103RB).
Parameters:
[in] chn channel number (0 or 1)
[in] enable 0: channel disabled, 1: channel enabled.
Returns:
< 0 if DAC channel not supported (e.g. STM32F103RB)
s32 MIOS32_BOARD_DAC_PinSet ( u8  chn,
u16  value
This function sets an output channel to a given 16-bit value.
Note that actually the DAC will work at 12-bit resolution. The lowest 4 bits are ignored (reserved for future STM chips).
Parameters:
[in] value the 16-bit value (0..65535). Lowest 4 bits are ignored.
Returns:
s32 MIOS32_BOARD_Init ( u32  mode  )
Initializes MIOS32_BOARD driver
Parameters:
[in] mode currently only mode 0 supported
Returns:
< 0 if initialisation failed
s32 MIOS32_BOARD_J10_Get ( void   )
This function returns the state of all pins of J10
Returns:
8 bits which are forwarded from J10
s32 MIOS32_BOARD_J10_PinGet ( u8  pin  )
This function returns the state of a single pin of J10
Parameters:
[in] pin the pin number (0..7)
Returns:
< 0 if pin not available
>= 0: input state of pin
s32 MIOS32_BOARD_J10_PinInit ( u8  pin,
Initializes a J10 pin
Parameters:
[in] mode the pin mode
  • MIOS32_BOARD_PIN_MODE_IGNORE: configuration shouldn't be touched
  • MIOS32_BOARD_PIN_MODE_ANALOG: select analog input mode (default)
  • MIOS32_BOARD_PIN_MODE_INPUT: pin is used as input w/o pull device (floating)
  • MIOS32_BOARD_PIN_MODE_INPUT_PD: pin is used as input, internal pull down enabled
  • MIOS32_BOARD_PIN_MODE_INPUT_PU: pin is used as input, internal pull up enabled
  • MIOS32_BOARD_PIN_MODE_OUTPUT_PP: pin is used as output in push-pull mode
  • MIOS32_BOARD_PIN_MODE_OUTPUT_OD: pin is used as output in open drain mode
Returns:
s32 MIOS32_BOARD_J10_PinSet ( u8  pin,
u8  value
This function sets a single pin of J10
Parameters:
[in] value the pin value (0 or 1)
Returns:
< 0 on errors
s32 MIOS32_BOARD_J10_Set ( u16  value  )
This function sets all pins of J10 at once
Parameters:
[in] value 8 bits which are forwarded to J10
Returns:
< 0 on errors
s32 MIOS32_BOARD_J15_DataSet ( u8  data  )
This function is used by LCD drivers under $MIOS32_PATH/modules/app_lcd to output an 8bit value on the data lines
Parameters:
[in] data the 8bit value
Returns:
< 0 if access to data port not supported by board
s32 MIOS32_BOARD_J15_E_Set ( u8  lcd,
u8  e
This function is used by LCD drivers under $MIOS32_PATH/modules/app_lcd to set the E pin
Parameters:
[in] lcd display port (0=J15A, 1=J15B)
[in] e state of the E pin
Returns:
< 0 if access to E pin not supported by board
s32 MIOS32_BOARD_J15_PollUnbusy ( u8  lcd,
u32  time_out
This function is used by LCD drivers under $MIOS32_PATH/modules/app_lcd to poll the busy bit (D7) of a LCD
Parameters:
[in] time_out how many times should the busy bit be polled?
Returns:
-1 if LCD not available
-2 on timeout return >= 0 on success
s32 MIOS32_BOARD_J15_PortInit ( u32  mode  )
Initializes the J15 port
Parameters:
[in] mode
  • 0: J15 pins are configured in Push Pull Mode (3.3V)
  • 1: J15 pins are configured in Open Drain mode (perfect for 3.3V->5V levelshifting)
Returns:
s32 MIOS32_BOARD_J15_RS_Set ( u8  rs  )
This function is used by LCD drivers under $MIOS32_PATH/modules/app_lcd to set the RS pin
Parameters:
[in] rs state of the RS pin
Returns:
< 0 if access to RS pin not supported by board
s32 MIOS32_BOARD_J15_RW_Set ( u8  rw  )
This function is used by LCD drivers under $MIOS32_PATH/modules/app_lcd to set the RW pin
Parameters:
[in] rw state of the RW pin
Returns:
< 0 if access to RW pin not supported by board
s32 MIOS32_BOARD_J15_SerDataShift ( u8  data  )
This function is used by LCD drivers under $MIOS32_PATH/modules/app_lcd to shift an 8bit data value to LCDs with serial interface (SCLK connected to J15A:E, Data line connected to J15A:RW)
Parameters:
Returns:
s32 MIOS32_BOARD_J28_Get ( void   )
This function returns the state of all pins of J28
Returns:
8 bits which are forwarded from J28
s32 MIOS32_BOARD_J28_PinGet ( u8  pin  )
This function returns the state of a single pin of J28
Parameters:
Returns:
s32 MIOS32_BOARD_J28_PinInit ( u8  pin,
Initializes a J28 pin
Parameters:
[in] pin the pin number (0..3)
Returns:
s32 MIOS32_BOARD_J28_PinSet ( u8  pin,
u8  value
This function sets a single pin of J28
Parameters:
Returns:
< 0 on errors
s32 MIOS32_BOARD_J28_Set ( u16  value  )
This function sets all pins of J28 at once
Parameters:
[in] value 8 bits which are forwarded to J28
Returns:
< 0 on errors
s32 MIOS32_BOARD_J5_Get ( void   )
This function returns the state of all pins of J5
Returns:
8 bits which are forwarded from J5A/B
s32 MIOS32_BOARD_J5_PinGet ( u8  pin  )
This function returns the state of a single pin of J5
Parameters:
Returns:
s32 MIOS32_BOARD_J5_PinInit ( u8  pin,
Initializes a J5 pin
Parameters:
Returns:
s32 MIOS32_BOARD_J5_PinSet ( u8  pin,
u8  value
This function sets a single pin of J5
Parameters:
Returns:
< 0 on errors
s32 MIOS32_BOARD_J5_Set ( u16  value  )
This function sets all pins of J5 at once
Parameters:
[in] value 8 bits which are forwarded to J5A/B
Returns:
< 0 on errors
u32 MIOS32_BOARD_LED_Get ( void   )
Returns the status of all LEDs
Returns:
status of all LEDs
s32 MIOS32_BOARD_LED_Init ( u32  leds  )
Initializes LEDs of the board
Parameters:
[in] leds mask contains a flag for each LED which should be initialized
  • MBHP_CORE_STM32: 1 LED (flag 0: green)
  • STM32_PRIMER: 2 LEDs (flag 0: green, flag 1: red)
Returns:
0 if initialisation passed
-1 if no LEDs specified for board
-2 if one or more LEDs not available on board
s32 MIOS32_BOARD_LED_Set ( u32  leds,
u32  value
Sets one or more LEDs to the given value(s)
Parameters:
[in] leds mask contains a flag for each LED which should be changed
[in] value contains the value which should be set
Returns:
Generated on Tue May 1 19:42:14 2012 for MIOS32 by  doxygen 1.4.7
