include/mios32/mios32_midi.h File Reference
Data Structures
union  mios32_midi_package_t
Defines
#define MIOS32_MIDI_DEFAULT_PORT   USB0
#define MIOS32_MIDI_DEBUG_PORT   USB0
#define MIOS32_MIDI_SYSEX_DEBUG   0x0d
#define MIOS32_MIDI_SYSEX_DISACK   0x0e
#define MIOS32_MIDI_SYSEX_ACK   0x0f
#define MIOS32_MIDI_SYSEX_DISACK_LESS_BYTES_THAN_EXP   0x01
#define MIOS32_MIDI_SYSEX_DISACK_MORE_BYTES_THAN_EXP   0x02
#define MIOS32_MIDI_SYSEX_DISACK_WRONG_CHECKSUM   0x03
#define MIOS32_MIDI_SYSEX_DISACK_WRITE_FAILED   0x04
#define MIOS32_MIDI_SYSEX_DISACK_WRITE_ACCESS   0x05
#define MIOS32_MIDI_SYSEX_DISACK_MIDI_TIMEOUT   0x06
#define MIOS32_MIDI_SYSEX_DISACK_WRONG_DEBUG_CMD   0x07
#define MIOS32_MIDI_SYSEX_DISACK_WRONG_ADDR_RANGE   0x08
#define MIOS32_MIDI_SYSEX_DISACK_ADDR_NOT_ALIGNED   0x09
#define MIOS32_MIDI_SYSEX_DISACK_BS_NOT_AVAILABLE   0x0a
#define MIOS32_MIDI_SYSEX_DISACK_OVERRUN   0x0b
#define MIOS32_MIDI_SYSEX_DISACK_FRAME_ERROR   0x0c
#define MIOS32_MIDI_SYSEX_DISACK_UNKNOWN_QUERY   0x0d
#define MIOS32_MIDI_SYSEX_DISACK_INVALID_COMMAND   0x0e
#define MIOS32_MIDI_SYSEX_DISACK_PROG_ID_NOT_ALLOWED   0x0f
#define MIOS32_MIDI_SYSEX_DISACK_UNSUPPORTED_DEBUG   0x10
Enumerations
enum  mios32_midi_port_t {
  DEFAULT = 0x00, MIDI_DEBUG = 0x01, USB0 = 0x10, USB1 = 0x11,
  USB2 = 0x12, USB3 = 0x13, USB4 = 0x14, USB5 = 0x15,
  USB6 = 0x16, USB7 = 0x17, UART0 = 0x20, UART1 = 0x21,
  UART2 = 0x22, UART3 = 0x23, IIC0 = 0x30, IIC1 = 0x31,
  IIC2 = 0x32, IIC3 = 0x33, IIC4 = 0x34, IIC5 = 0x35,
  IIC6 = 0x36, IIC7 = 0x37, OSC0 = 0x40, OSC1 = 0x41,
  OSC2 = 0x42, OSC3 = 0x43, OSC4 = 0x44, OSC5 = 0x45,
  OSC6 = 0x46, OSC7 = 0x47
enum  mios32_midi_event_t {
  NoteOff = 0x8, NoteOn = 0x9, PolyPressure = 0xa, CC = 0xb,
  ProgramChange = 0xc, Aftertouch = 0xd, PitchBend = 0xe
enum  mios32_midi_chn_t {
  Chn1, Chn2, Chn3, Chn4,
  Chn5, Chn6, Chn7, Chn8,
  Chn9, Chn10, Chn11, Chn12,
  Chn13, Chn14, Chn15, Chn16
enum  mios32_midi_sysex_cmd_state_t { MIOS32_MIDI_SYSEX_CMD_STATE_BEGIN, MIOS32_MIDI_SYSEX_CMD_STATE_CONT, MIOS32_MIDI_SYSEX_CMD_STATE_END }
Functions
s32 MIOS32_MIDI_Init (u32 mode)
s32 MIOS32_MIDI_CheckAvailable (mios32_midi_port_t port)
s32 MIOS32_MIDI_RS_OptimisationSet (mios32_midi_port_t port, u8 enable)
s32 MIOS32_MIDI_RS_OptimisationGet (mios32_midi_port_t port)
s32 MIOS32_MIDI_RS_Reset (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendPackage_NonBlocking (mios32_midi_port_t port, mios32_midi_package_t package)
s32 MIOS32_MIDI_SendPackage (mios32_midi_port_t port, mios32_midi_package_t package)
s32 MIOS32_MIDI_SendEvent (mios32_midi_port_t port, u8 evnt0, u8 evnt1, u8 evnt2)
s32 MIOS32_MIDI_SendNoteOff (mios32_midi_port_t port, mios32_midi_chn_t chn, u8 note, u8 vel)
s32 MIOS32_MIDI_SendNoteOn (mios32_midi_port_t port, mios32_midi_chn_t chn, u8 note, u8 vel)
s32 MIOS32_MIDI_SendPolyPressure (mios32_midi_port_t port, mios32_midi_chn_t chn, u8 note, u8 val)
s32 MIOS32_MIDI_SendCC (mios32_midi_port_t port, mios32_midi_chn_t chn, u8 cc_number, u8 val)
s32 MIOS32_MIDI_SendProgramChange (mios32_midi_port_t port, mios32_midi_chn_t chn, u8 prg)
s32 MIOS32_MIDI_SendAftertouch (mios32_midi_port_t port, mios32_midi_chn_t chn, u8 val)
s32 MIOS32_MIDI_SendPitchBend (mios32_midi_port_t port, mios32_midi_chn_t chn, u16 val)
s32 MIOS32_MIDI_SendSysEx (mios32_midi_port_t port, u8 *stream, u32 count)
s32 MIOS32_MIDI_SendMTC (mios32_midi_port_t port, u8 val)
s32 MIOS32_MIDI_SendSongPosition (mios32_midi_port_t port, u16 val)
s32 MIOS32_MIDI_SendSongSelect (mios32_midi_port_t port, u8 val)
s32 MIOS32_MIDI_SendTuneRequest (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendClock (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendTick (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendStart (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendStop (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendContinue (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendActiveSense (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendReset (mios32_midi_port_t port)
s32 MIOS32_MIDI_SendDebugMessage (char *format,...)
s32 MIOS32_MIDI_SendDebugString (char *str)
s32 MIOS32_MIDI_SendDebugHexDump (u8 *src, u32 len)
s32 MIOS32_MIDI_Receive_Handler (void *callback_event)
s32 MIOS32_MIDI_Periodic_mS (void)
s32 MIOS32_MIDI_DirectTxCallback_Init (s32(*callback_tx)(mios32_midi_port_t port, mios32_midi_package_t package))
s32 MIOS32_MIDI_DirectRxCallback_Init (s32(*callback_rx)(mios32_midi_port_t port, u8 midi_byte))
s32 MIOS32_MIDI_SendByteToRxCallback (mios32_midi_port_t port, u8 midi_byte)
s32 MIOS32_MIDI_SendPackageToRxCallback (mios32_midi_port_t port, mios32_midi_package_t midi_package)
s32 MIOS32_MIDI_DefaultPortSet (mios32_midi_port_t port)
mios32_midi_port_t MIOS32_MIDI_DefaultPortGet (void)
s32 MIOS32_MIDI_DebugPortSet (mios32_midi_port_t port)
mios32_midi_port_t MIOS32_MIDI_DebugPortGet (void)
s32 MIOS32_MIDI_DeviceIDSet (u8 device_id)
u8 MIOS32_MIDI_DeviceIDGet (void)
s32 MIOS32_MIDI_SysExCallback_Init (s32(*callback_sysex)(mios32_midi_port_t port, u8 sysex_byte))
s32 MIOS32_MIDI_DebugCommandCallback_Init (s32(*callback_debug_command)(mios32_midi_port_t port, char c))
s32 MIOS32_MIDI_TimeOutCallback_Init (s32(*callback_timeout)(mios32_midi_port_t port))
Variables
const u8 mios32_midi_pcktype_num_bytes [16]
const u8 mios32_midi_expected_bytes_common [8]
 Number if expected bytes for a common MIDI event - 1.
const u8 mios32_midi_expected_bytes_system [16]
 Number if expected bytes for a system MIDI event - 1.
const u8 mios32_midi_sysex_header [5]
 should only be used by MIOS32 internally and by the Bootloader!
Define Documentation
Enumeration Type Documentation
Enumerator:
Chn1
Chn2
Chn3
Chn4
Chn5
Chn6
Chn7
Chn8
Chn9
Chn10
Chn11
Chn12
Chn13
Chn14
Chn15
Chn16
Enumerator:
NoteOff
NoteOn
PolyPressure
CC
ProgramChange
Aftertouch
PitchBend
Enumerator:
DEFAULT
MIDI_DEBUG
USB0
USB1
USB2
USB3
USB4
USB5
USB6
USB7
UART0
UART1
UART2
UART3
IIC0
IIC1
IIC2
IIC3
IIC4
IIC5
IIC6
IIC7
OSC0
OSC1
OSC2
OSC3
OSC4
OSC5
OSC6
OSC7
Enumerator:
Function Documentation
s32 MIOS32_MIDI_SysExCallback_Init ( s32(*)(mios32_midi_port_t port, u8 sysex_byte)  callback_sysex  )
Generated on Tue May 1 19:42:13 2012 for MIOS32 by  doxygen 1.4.7
