#include <mios32.h>#include <app_lcd.h>#include "UWindows.h"#include "UW_CharSet.h"Defines | |
| #define | MAX_X 128 |
| #define | MAX_Y 64 |
| #define | CURSOR_SIZE 3 |
Functions | |
| void | swap (u32 *a, u32 *b) |
| void | UW_Add (UW_Window *pWindow, UW_Type Type, UW_Window *pParent, void *ExtraProperties) |
| API to add a new UWindow. | |
| void | UW_DrawLine (s32 x1, s32 y1, s32 x2, s32 y2, u16 color) |
| void | UW_ListBoxSetItemHeight (UW_Window *pListBox, u8 value) |
| API Set List Box Items Height. | |
| void | UW_ListBoxAddItem (UW_Window *ListBox, UW_Window *Item) |
| API add item to list box. | |
| void | UW_ListBoxRemoveItem (UW_Window *ListBox, UW_Window *Item) |
| API remove item from list box. | |
| UW_Window * | UW_ListBoxGetActiveItem (UW_Window *ListBox) |
| get active item | |
| UW_Window * | UW_ListBoxGetItem (UW_Window *ListBox, u32 index) |
| get item with a certain index | |
| s32 | UW_ListBoxGetIndex (UW_Window *ListBox, UW_Window *Item) |
| void | ExitUWindows (void) |
| Eixt Windows. | |
| void | UW_Init (void) |
| API to initialize UWindows. | |
| void | UW_Run (void) |
| API main running function of UWindows. | |
Variables | |
| const char | ExitLabel [] = "SHUT DOWN" |
| bool | Refresh |
| bool | bExit |
| UW_Window | UWindows |
| UW_Window | ExitBtn |
| u8 | UWImage [4 *1040] |
| u16 | Colors [4] = {BLACK,BLUE,GRAY,WHITE} |
| UW_Window * | pUW_Infocus |
| u8 | CursorXPos |
| u8 | CursorYPos |
| const u8 | CurrentFont [224 *14] |
| #define CURSOR_SIZE 3 |
| #define MAX_X 128 |
| #define MAX_Y 64 |
| void ExitUWindows | ( | void | ) |
Eixt Windows.
set bExit Flag to exit Windows
This function will : add a new UWindow Objet to pParent do all nessecary and default initializations attach the New Window to its extra properties if available
| [in] | pWindow | : Pointer to new window object |
| [in] | Type | : Type of the new windows |
| [in] | pParent | : Ponter to Parent window |
| [in] | ExtraProperties | : Pointer to Extra properties object |
| void UW_Init | ( | void | ) |
This should be called at Application Init
This is used add item to list box
| [in] | pListBox,: | pointer to UWindow Object treated as ListBox |
| [in] | Item,: | a new Item, pointer t UWindow treated as EditBox |
get active item
This is used get current item currently pointed to in ListBox
Items are indexed from 0 to TotalCount-1, This is used get item with certain index
| [in] | index,: | index of the Item |
This is used remove item from list box
This should set List Box Items Height
| [in] | value | : Height of Items |
| void UW_Run | ( | void | ) |
This should be called at Application Handler
| bool bExit |
| const u8 CurrentFont[224 *14] |
| const char ExitLabel[] = "SHUT DOWN" |
| bool Refresh |
1.6.1
