/home/midibox/svn_snapshot/mios32/trunk/modules/fatfs/src/diskio.h File Reference
#include "integer.h"
Defines
#define _READONLY   0
#define _USE_IOCTL   1
#define STA_NOINIT   0x01
#define STA_NODISK   0x02
#define STA_PROTECT   0x04
#define CTRL_SYNC   0
#define GET_SECTOR_COUNT   1
#define GET_SECTOR_SIZE   2
#define GET_BLOCK_SIZE   3
#define CTRL_POWER   4
#define CTRL_LOCK   5
#define CTRL_EJECT   6
#define MMC_GET_TYPE   10
#define MMC_GET_CSD   11
#define MMC_GET_CID   12
#define MMC_GET_OCR   13
#define MMC_GET_SDSTAT   14
#define ATA_GET_REV   20
#define ATA_GET_MODEL   21
#define ATA_GET_SN   22
#define _DISKIO
Typedefs
typedef BYTE DSTATUS
Enumerations
enum  DRESULT {
  RES_OK = 0, RES_ERROR, RES_WRPRT, RES_NOTRDY,
  RES_PARERR
Functions
BOOL assign_drives (int argc, char *argv[])
DSTATUS disk_initialize (BYTE)
DSTATUS disk_status (BYTE)
DRESULT disk_read (BYTE, BYTE *, DWORD, BYTE)
DRESULT disk_write (BYTE, const BYTE *, DWORD, BYTE)
DRESULT disk_ioctl (BYTE, BYTE, void *)
Define Documentation
#define _DISKIO
#define _READONLY   0
#define CTRL_LOCK   5
#define CTRL_SYNC   0
Typedef Documentation
Enumeration Type Documentation
enum DRESULT
Enumerator:
RES_OK
RES_ERROR
RES_WRPRT
RES_NOTRDY
RES_PARERR
Function Documentation
BOOL assign_drives ( int  argc,
char *  argv[]
DSTATUS disk_initialize ( BYTE   )
DRESULT disk_ioctl ( BYTE  ,
BYTE  ,
void *
DRESULT disk_read ( BYTE  ,
BYTE ,
DWORD  ,
BYTE
DSTATUS disk_status ( BYTE   )
DRESULT disk_write ( BYTE  ,
const BYTE ,
DWORD  ,
BYTE
