MBNG_FILE_K
Detailed Description
Keyboard calibration data
NOTE: before accessing the SD Card, the upper level function should synchronize with the SD Card semaphore! MUTEX_SDCARD_TAKE; // to take the semaphore MUTEX_SDCARD_GIVE; // to release the semaphore
Define Documentation
| #define DEBUG_VERBOSE_LEVEL 1 |
Include files for optional debugging messages via DEBUG_MSG (defined in mios32_config.h)
| #define MBNG_FILES_PATH "/" |
Function Documentation
| s32 MBNG_FILE_K_Init |
u32 |
mode |
Global variables Initialisation
| s32 MBNG_FILE_K_Load |
char * |
filename |
Loads keyboard file Called from MBNG_FILE_CheckSDCard() when the SD card has been connected
- Parameters:
| filename | the filename which should be read |
- Returns:
- < 0 on errors
| s32 MBNG_FILE_K_Read |
char * |
filename |
Reads the keyboard calibration data file content
- Parameters:
- Returns:
- < 0 on errors
| s32 MBNG_FILE_K_Unload |
void |
Unloads keyboard file Called from MBNG_FILE_CheckSDCard() when the SD card has been disconnected
- Returns:
- < 0 on errors
| s32 MBNG_FILE_K_Valid |
void |
- Returns:
- 1 if current keyboard file valid
0 if current keyboard file not valid
| s32 MBNG_FILE_K_Write |
char * |
filename |
writes data into keyboard calibration file
- Parameters:
| filename | the filename which should be written |
- Returns:
- < 0 on errors (error codes are documented in seq_file.h)
