NOTESTACK
Functions
s32 NOTESTACK_Init (notestack_t *n, notestack_mode_t mode, notestack_item_t *note_items, u8 size)
s32 NOTESTACK_Push (notestack_t *n, u8 new_note, u8 tag)
s32 NOTESTACK_Pop (notestack_t *n, u8 old_note)
s32 NOTESTACK_CountActiveNotes (notestack_t *n)
s32 NOTESTACK_RemoveNonActiveNotes (notestack_t *n)
s32 NOTESTACK_Clear (notestack_t *n)
s32 NOTESTACK_SendDebugMessage (notestack_t *n)
Detailed Description
Generic Notestack Module
Usage Examples: $MIOS32_PATH/apps/tutorial/016_aout $MIOS32_PATH/apps/tutorial/017_sequencer $MIOS32_PATH/apps/tutorial/018_arpeggiator $MIOS32_PATH/apps/sequencers/midibox_seq_v4/core/seq_midi_in.c
Function Documentation
s32 NOTESTACK_Clear ( notestack_t n  )
Clears the note stack
Parameters:
[in] *n pointer to notestack structure
Returns:
< 0 on errors
s32 NOTESTACK_CountActiveNotes ( notestack_t n  )
Counts all active notes in notestack
Parameters:
Returns:
< 0 on errors
0 if no active note
> 0 if active notes have been found
s32 NOTESTACK_Init ( notestack_t n,
notestack_item_t note_items,
u8  size
Initializes a Notestack
Has to be called before NOTESTACK_Push/Pop/Clear functions are used!
Parameters:
[in] mode one of following modes:
  • NOTESTACK_MODE_PUSH_TOP: new notes are added to the top of the note stack
  • NOTESTACK_MODE_PUSH_BOTTOM: new notes are added to the bottom of the note stack
  • NOTESTACK_MODE_PUSH_TOP_HOLD: same like above, but notes won't be removed so long there is a free item in note stack. Instead, they will be marked with .depressed=1
  • NOTESTACK_MODE_PUSH_BOTTOM_HOLD,: same like above, but new notes will be added to the bottom of the note stack
  • NOTESTACK_MODE_SORT: Notes will be sorted
  • NOTESTACK_MODE_SORT_HOLD: Like above, but notes won't be removed so long there is a free item in note stack. Instead, they will be marked with .depressed=1
[in] *note_items pointer to notestack_item_t array which stores the notes and related informations
[in] size number of note items stored in the array
Returns:
< 0 if initialisation failed
s32 NOTESTACK_Pop ( notestack_t n,
u8  old_note
Removes a note from the stack
Parameters:
[in] old_note the note number which should be removed (1..127)
Returns:
< 0 on errors
0 if note hasn't been found
1 if note has been found and removed from stack (in hold mode: marked as depressed)
2 only in hold mode: if all notes are depressed now
s32 NOTESTACK_Push ( notestack_t n,
u8  new_note,
u8  tag
Pushes a new note, bundled with a tag, to the note stack
Parameters:
[in] new_note the note number which should be added (1..127)
[in] tag an optional tag which is bundled with the note. It can contain a voice number, the velocity, or...
Returns:
< 0 on errors
s32 NOTESTACK_RemoveNonActiveNotes ( notestack_t n  )
Removes all non-active notes from notestack
Parameters:
Returns:
< 0 on errors
s32 NOTESTACK_SendDebugMessage ( notestack_t n  )
Sends the content of the Notestack to the MIOS Terminal
Parameters:
Returns:
< 0 on errors
