SMTP E-mail sender
[Apps]
Data Structures |
| struct | smtp_state |
Files |
| file | smtp.c |
| file | smtp.h |
Defines |
| #define | ISO_nl 0x0a |
| #define | ISO_cr 0x0d |
| #define | ISO_period 0x2e |
| #define | ISO_2 0x32 |
| #define | ISO_3 0x33 |
| #define | ISO_4 0x34 |
| #define | ISO_5 0x35 |
| #define | SMTP_ERR_OK 0 |
| #define | SMTP_SEND(to, cc, from, subject, msg) smtp_send(to, cc, from, subject, msg, strlen(msg)) |
Typedefs |
| typedef struct smtp_state | uip_tcp_appstate_t |
Functions |
| void | smtp_done (unsigned char error) |
| void | smtp_init (void) |
| void | smtp_configure (char *localhostname, u16_t *smtpserver) |
| unsigned char | smtp_send (char *to, char *from, char *subject, char *msg, u16_t msglen) |
| void | smtp_appcall (void) |
Detailed Description
The Simple Mail Transfer Protocol (SMTP) as defined by RFC821 is the standard way of sending and transfering e-mail on the Internet. This simple example implementation is intended as an example of how to implement protocols in uIP, and is able to send out e-mail but has not been extensively tested.
Define Documentation
Error number that signifies a non-error condition.
| #define SMTP_SEND |
to, |
cc, |
from, |
subject, |
msg |
Typedef Documentation
Function Documentation
| void smtp_appcall |
void |
| void smtp_configure |
char * |
localhostname, |
u16_t * |
smtpserver | |
| void smtp_done |
unsigned char |
error |
Callback function that is called when an e-mail transmission is done.
This function must be implemented by the module that uses the SMTP module.
- Parameters:
| error | The number of the error if an error occured, or SMTP_ERR_OK. |
| unsigned char smtp_send |
char * |
to, |
char * |
from, |
char * |
subject, |
char * |
msg, |
u16_t |
msglen | |
