Defines | |
| #define | _BIT(n) (((UNS_32)(1)) << (n)) |
| #define | _SBF(f, v) (((UNS_32)(v)) << (f)) |
| #define | _BITMASK(field_width) ( _BIT(field_width) - 1) |
| #define | SUCCESS 0 |
| #define | NELEMENTS(array) (sizeof (array) / sizeof (array[0])) |
| #define | STATIC static |
| #define | EXTERN extern |
| #define | _NO_ERROR (INT_32)(0) |
| #define | _ERROR (INT_32)(-1) |
| #define | LPC_DEV_UNKNOWN (INT_32)(-2) |
| #define | LPC_NOT_SUPPORTED (INT_32)(-3) |
| #define | LPC_NOT_OPEN (INT_32)(-4) |
| #define | LPC_IN_USE (INT_32)(-5) |
| #define | LPC_PIN_CONFLICT (INT_32)(-6) |
| #define | LPC_BAD_PARAMS (INT_32)(-7) |
| #define | LPC_BAD_HANDLE (INT_32)(-8) |
| #define | LPC_BAD_CLK (INT_32)(-9) |
| #define | LPC_CANT_START (INT_32)(-10) |
| #define | LPC_CANT_STOP (INT_32)(-11) |
| #define | SMA_DEV_UNKNOWN LPC_DEV_UNKNOWN |
| #define | SMA_NOT_SUPPORTED LPC_NOT_SUPPORTED |
| #define | SMA_NOT_OPEN LPC_NOT_OPEN |
| #define | SMA_IN_USE LPC_IN_USE |
| #define | SMA_PIN_CONFLICT LPC_PIN_CONFLICT |
| #define | SMA_BAD_PARAMS LPC_BAD_PARAMS |
| #define | SMA_BAD_HANDLE LPC_BAD_HANDLE |
| #define | SMA_BAD_CLK LPC_BAD_CLK |
| #define | SMA_CANT_START LPC_CANT_START |
| #define | SMA_CANT_STOP LPC_CANT_STOP |
| #define | MAX(a, b) (((a) > (b)) ? (a) : (b)) |
| #define | MIN(a, b) (((a) < (b)) ? (a) : (b)) |
Typedefs | |
| typedef char | CHAR |
| typedef unsigned char | UNS_8 |
| typedef signed char | INT_8 |
| typedef unsigned short | UNS_16 |
| typedef signed short | INT_16 |
| typedef unsigned int | UNS_32 |
| typedef signed int | INT_32 |
| typedef long long | INT_64 |
| typedef unsigned long long | UNS_64 |
| typedef INT_32 | BOOL_32 |
| typedef INT_16 | BOOL_16 |
| typedef INT_8 | BOOL_8 |
| typedef void(* | PFV )() |
| typedef INT_32(* | PFI )() |
| typedef INT_32 | STATUS |
| #define _BIT | ( | n | ) | (((UNS_32)(1)) << (n)) |
| #define _BITMASK | ( | field_width | ) | ( _BIT(field_width) - 1) |
| #define _ERROR (INT_32)(-1) |
| #define _NO_ERROR (INT_32)(0) |
| #define _SBF | ( | f, | |||
| v | ) | (((UNS_32)(v)) << (f)) |
| #define EXTERN extern |
| #define LPC_BAD_CLK (INT_32)(-9) |
| #define LPC_BAD_HANDLE (INT_32)(-8) |
| #define LPC_BAD_PARAMS (INT_32)(-7) |
| #define LPC_CANT_START (INT_32)(-10) |
| #define LPC_CANT_STOP (INT_32)(-11) |
| #define LPC_DEV_UNKNOWN (INT_32)(-2) |
| #define LPC_IN_USE (INT_32)(-5) |
| #define LPC_NOT_OPEN (INT_32)(-4) |
| #define LPC_NOT_SUPPORTED (INT_32)(-3) |
| #define LPC_PIN_CONFLICT (INT_32)(-6) |
| #define MAX | ( | a, | |||
| b | ) | (((a) > (b)) ? (a) : (b)) |
| #define MIN | ( | a, | |||
| b | ) | (((a) < (b)) ? (a) : (b)) |
| #define NELEMENTS | ( | array | ) | (sizeof (array) / sizeof (array[0])) |
| #define SMA_BAD_CLK LPC_BAD_CLK |
| #define SMA_BAD_HANDLE LPC_BAD_HANDLE |
| #define SMA_BAD_PARAMS LPC_BAD_PARAMS |
| #define SMA_CANT_START LPC_CANT_START |
| #define SMA_CANT_STOP LPC_CANT_STOP |
| #define SMA_DEV_UNKNOWN LPC_DEV_UNKNOWN |
| #define SMA_IN_USE LPC_IN_USE |
| #define SMA_NOT_OPEN LPC_NOT_OPEN |
| #define SMA_NOT_SUPPORTED LPC_NOT_SUPPORTED |
| #define SMA_PIN_CONFLICT LPC_PIN_CONFLICT |
| #define STATIC static |
| #define SUCCESS 0 |
| typedef char CHAR |
| typedef signed short INT_16 |
| typedef signed int INT_32 |
| typedef long long INT_64 |
| typedef signed char INT_8 |
| typedef void(* PFV)() |
| typedef unsigned short UNS_16 |
| typedef unsigned int UNS_32 |
| typedef unsigned long long UNS_64 |
| typedef unsigned char UNS_8 |
1.6.1
