/home/midibox/svn_snapshot/mios32/trunk/modules/uwindows/list.h File Reference
Data Structures
struct  list_head
Defines
#define LIST_HEAD_INIT(name)   { &(name), &(name) }
#define LIST_HEAD(name)   struct list_head name = LIST_HEAD_INIT(name)
#define INIT_LIST_HEAD(ptr)
#define list_entry(ptr, type, member)   ((type *)((char *)(ptr)-(unsigned long)(&((type *)0)->member)))
#define list_for_each(pos, head)
#define list_for_each_prev(pos, head)
#define list_for_each_safe(pos, n, head)
#define list_for_each_entry(pos, head, member)
#define list_for_each_entry_safe(pos, n, head, member)
Define Documentation
#define INIT_LIST_HEAD ( ptr   )
Value:
do { \
        (ptr)->next = (ptr); (ptr)->prev = (ptr); \
} while (0)
#define list_entry ( ptr,
type,
member   )     ((type *)((char *)(ptr)-(unsigned long)(&((type *)0)->member)))
list_entry - get the struct for this entry : the &struct list_head pointer. : the type of the struct this is embedded in. : the name of the list_struct within the struct.
#define list_for_each ( pos,
head   )
Value:
for (pos = (head)->next; pos != (head); \
                pos = pos->next)
list_for_each - iterate over a list : the &struct list_head to use as a loop counter. : the head for your list.
#define list_for_each_entry ( pos,
head,
member   )
Value:
for (pos = list_entry((head)->next, typeof(*pos), member);      \
             &pos->member != (head);                                    \
             pos = list_entry(pos->member.next, typeof(*pos), member))
list_for_each_entry - iterate over list of given type : the type * to use as a loop counter. : the head for your list. : the name of the list_struct within the struct.
#define list_for_each_entry_safe ( pos,
n,
head,
member   )
Value:
for (pos = list_entry((head)->next, typeof(*pos), member),      \
                n = list_entry(pos->member.next, typeof(*pos), member); \
             pos = n, n = list_entry(n->member.next, typeof(*n), member))
list_for_each_entry_safe - iterate over list of given type safe against removal of list entry : the type * to use as a loop counter.
: another type * to use as temporary storage : the head for your list. : the name of the list_struct within the struct.
#define list_for_each_prev ( pos,
head   )
Value:
for (pos = (head)->prev; pos != (head); \
                pos = pos->prev)
list_for_each_prev - iterate over a list backwards : the &struct list_head to use as a loop counter. : the head for your list.
#define list_for_each_safe ( pos,
n,
head   )
Value:
for (pos = (head)->next, n = pos->next; pos != (head); \
                pos = n, n = pos->next)
list_for_each_safe - iterate over a list safe against removal of list entry : the &struct list_head to use as a loop counter.
: another &struct list_head to use as temporary storage : the head for your list.
#define LIST_HEAD ( name   )     struct list_head name = LIST_HEAD_INIT(name)
#define LIST_HEAD_INIT ( name   )     { &(name), &(name) }
