Main Page
Related Pages
Modules
Data Structures
Files
Data Structures
Data Structure Index
Data Fields
mbng_event_item_t Struct Reference
#include <mbng_event.h>
Collaboration diagram for mbng_event_item_t:
legend
Data Fields
u16
id
u16
hw_id
mbng_event_cond_t
cond
u32
enabled_ports
u16
pool_address
mbng_event_flags_t
flags
mbng_event_custom_flags_t
custom_flags
u16
fwd_id
u16
value
u16
fwd_value
s16
min
s16
max
s16
offset
u16
matrix_pin
mbng_event_rgb_t
rgb
mbng_event_hsv_t
hsv
mbng_event_syxdump_pos_t
syxdump_pos
u32
stream_size
u8
stream
u8
map
u8
map_ix
u8
bank
u8
secondary_value
u8
lcd
u8
lcd_x
u8
lcd_y
char *
label
Field Documentation
u8
mbng_event_item_t::bank
mbng_event_cond_t
mbng_event_item_t::cond
mbng_event_item_t::custom_flags
u32
mbng_event_item_t::enabled_ports
mbng_event_flags_t
mbng_event_item_t::flags
u16
mbng_event_item_t::fwd_id
u16
mbng_event_item_t::fwd_value
mbng_event_hsv_t
mbng_event_item_t::hsv
u16
mbng_event_item_t::hw_id
u16
mbng_event_item_t::id
char*
mbng_event_item_t::label
u8
mbng_event_item_t::lcd
u8
mbng_event_item_t::lcd_x
u8
mbng_event_item_t::lcd_y
u8
mbng_event_item_t::map
u8
mbng_event_item_t::map_ix
u16
mbng_event_item_t::matrix_pin
s16
mbng_event_item_t::max
s16
mbng_event_item_t::min
s16
mbng_event_item_t::offset
u16
mbng_event_item_t::pool_address
mbng_event_rgb_t
mbng_event_item_t::rgb
u8
mbng_event_item_t::secondary_value
u8
mbng_event_item_t::stream
u32
mbng_event_item_t::stream_size
mbng_event_item_t::syxdump_pos
u16
mbng_event_item_t::value
The documentation for this struct was generated from the following file:
midibox_ng_v1/src/
mbng_event.h
Generated on 22 Jan 2016 for MIDIboxNG by
1.6.1
