#include "uip.h"#include "telnetd.h"#include "memb.h"#include "shell.h"#include <string.h>Data Structures | |
| struct | telnetd_line |
Defines | |
| #define | ISO_nl 0x0a |
| #define | ISO_cr 0x0d |
| #define | STATE_NORMAL 0 |
| #define | STATE_IAC 1 |
| #define | STATE_WILL 2 |
| #define | STATE_WONT 3 |
| #define | STATE_DO 4 |
| #define | STATE_DONT 5 |
| #define | STATE_CLOSE 6 |
| #define | TELNET_IAC 255 |
| #define | TELNET_WILL 251 |
| #define | TELNET_WONT 252 |
| #define | TELNET_DO 253 |
| #define | TELNET_DONT 254 |
Functions | |
| MEMB (linemem, struct telnetd_line, TELNETD_CONF_NUMLINES) | |
| void | shell_quit (char *str) |
| void | shell_prompt (char *str) |
| void | shell_output (char *str1, char *str2) |
| void | telnetd_init (void) |
| void | telnetd_appcall (void) |
| #define ISO_cr 0x0d |
| #define ISO_nl 0x0a |
| #define STATE_CLOSE 6 |
| #define STATE_DO 4 |
| #define STATE_DONT 5 |
| #define STATE_IAC 1 |
| #define STATE_NORMAL 0 |
| #define STATE_WILL 2 |
| #define STATE_WONT 3 |
| #define TELNET_DO 253 |
| #define TELNET_DONT 254 |
| #define TELNET_IAC 255 |
| #define TELNET_WILL 251 |
| #define TELNET_WONT 252 |
| MEMB | ( | linemem | , | |
| struct telnetd_line | , | |||
| TELNETD_CONF_NUMLINES | ||||
| void shell_output | ( | char * | str1, | |
| char * | str2 | |||
Print a string to the shell window.
This function is implemented by the shell GUI / telnet server and can be called by the shell back-end to output a string in the shell window. The string is automatically appended with a linebreak.
| str1 | The first half of the string to be output. | |
| str2 | The second half of the string to be output. |
| void shell_prompt | ( | char * | prompt | ) |
Print a prompt to the shell window.
This function can be used by the shell back-end to print out a prompt to the shell window.
| prompt | The prompt to be printed. |
| void shell_quit | ( | char * | ) |
Quit the shell.
| void telnetd_appcall | ( | void | ) |
| void telnetd_init | ( | void | ) |
1.6.1
