mididocs:seq:blm16x16_build_guide
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
mididocs:seq:blm16x16_build_guide [2016/03/29 10:58] – [Concept of the project] latigid_on | mididocs:seq:blm16x16_build_guide [2017/11/24 19:52] (current) – [Dimensions] latigid_on | ||
Line 113: | Line 113: | ||
- | * You can choose | + | * You can choose |
- | * Slider height: I specified 15mm shaft sliders, you could change these for 10mm. 15mm will protrude 13mm out of the case, which might be a bit long. 10mm will only protrude 8mm, so they would be less likely to break off and will probably be a bit more sturdy. TK. suggests 1k should work, the others are too high in resistance to get good jitter-free values (10k sliders with the shorter shaft don' | + | * Slider height: I specified 15mm shaft sliders, you could change these for 10mm. 15mm will protrude 13mm out of the case, which might be a bit long. 10mm will only protrude 8mm, so they would be less likely to break off and will probably be a bit more sturdy. TK. suggests 1k should work, the others are too high in resistance to get good jitter-free values (10k sliders with the shorter shaft aren' |
* You should use the indicated panel mount DIN, but a cheaper pair of DIN8 plugs might work. | * You should use the indicated panel mount DIN, but a cheaper pair of DIN8 plugs might work. | ||
* M2 hardware is a bit difficult to find in normal stores, but Boltbase on eBay has good deals. | * M2 hardware is a bit difficult to find in normal stores, but Boltbase on eBay has good deals. | ||
Line 123: | Line 123: | ||
* Soldering iron, I managed with a normal tip but it’s a bit tricky with some components | * Soldering iron, I managed with a normal tip but it’s a bit tricky with some components | ||
- | * Solder, probably leaded. 0.5mm will make the finer pitch stuff easier but again I managed | + | * Solder, probably leaded. 0.5mm is strongly recommended for at least the ICs (1206 can be easily done with 1mm solder). |
* Desoldering wick and/or solder pump. Useful when the pads get too much solder | * Desoldering wick and/or solder pump. Useful when the pads get too much solder | ||
* Tweezers to pick and place components | * Tweezers to pick and place components | ||
Line 131: | Line 131: | ||
* Flat work surface | * Flat work surface | ||
* Multimeter, test continuity between pads | * Multimeter, test continuity between pads | ||
+ | ==== Dimensions ==== | ||
+ | Here are the dimensions for the button, hole and slider locations. Note that the unmarked mounting holes are M3 (3.2mm diameter) | ||
mididocs/seq/blm16x16_build_guide.txt · Last modified: 2017/11/24 19:52 by latigid_on
