adding_buttons_for_bankstick_switching
How to add bankstick UP/DOWN buttons to mbSID v2
This is another draft. Actually it's just the source code that you'll need to add :D Make sure you've read the other tutorials that cover all the stuff needed to understand this one. This is not really a great way of achieving what we want, but it's good enough for now…
- In app_defines.h you'll need to find some space (1 byte) for a variable we'll name “BANK_STICK_NO”. This variable will hold the selected bankstick.
- In cs_menu_buttons.inc:
CS_MENU_BUTTON_BankUp ;; do nothing if button has been depressed btfsc MIOS_PARAMETER2, 0 return incf BANK_STICK_NO, W ; increment bank, load result into w goto CS_MENU_BUTTON_AssignBank CS_MENU_BUTTON_BankDown ;; do nothing if button has been depressed btfsc MIOS_PARAMETER2, 0 return decf BANK_STICK_NO, W ; decrement bank, load result into w ;; goto CS_MENU_BUTTON_AssignBank CS_MENU_BUTTON_AssignBank andlw 0x07 ; this keeps result from getting bigger than 7 movwf BANK_STICK_NO movwf CS_MENU_SID_M_BANK movff CS_MENU_SID_M_BANK, SID_BANK ;; mask out 'sent' flag bcf SID_PATCH, 7 call CS_MENU_EXEC_GoToMain return
adding_buttons_for_bankstick_switching.txt · Last modified: 2008/03/23 21:56 by 127.0.0.1
