coilwinder
Coil Winder
REAL:
CODE, FIRMWARE
Install MIOS Studio, connect a Core-Stm32F4 via USB, and Start the STUDIO
1. Upload MIOS BOOTLOADER
2. (only needet for Virgin Machines) type following commands into the MIOS-TERMINAL:
  • set lcd_type GLCD_SSD1306_ROTATED
  • set lcd_num_x 2
  • set lcd_num_y 1
  • set lcd_width 128
  • set lcd_height 64
  • store
3. Unzip the Firmware, and Upload the project.hex
4. Unconnect USB & Connect the USB again — finished.
5. If the Machine is not detected by mios studio, and you already checked the usb-connections, the device or the code is broken, for that you may search for “Bootload Switch”, please set it to “bLOAD”, now you can upload new & unbroken codes, dont forget to set it to “normal” back again - after upload new code - else the APP will not boot…
BUILD
Shemata
Community users working on it
  • Phatline = Programming, Documentation, Hardware-Prototype, Testing, Winding
Getting Involved ?
coilwinder.1680466043.txt.gz · Last modified: 2023/04/02 20:07 by phatline
