doutx2dinx1
DinX2DoutX1
it gives;
16 Digital Inputs
8 Digital Outputs
The Board is fully SMD, and made for pick and place - so no soldering required!
Shematic
Building and BOM
Its build by pick and place robots… so no need to build, or order any component
you need this PCB 1x for OpenPAD
BOM
Follwing list is for reference, and debugging only, no need to order them! all the parts are already soldered on the PCB!
| qty | reference | value | jlc | |
| 5 | C1, C3, C4, C5, C6 | 100n | C307331 | 81-GRM155R61E104KA7J |
| 1 | C2 | 10uF | C440198 | 81-GRM21BR61H106KE3K |
| 2 | DIN1,DIN2 | Gates | C124391 | 649-1012938391001ALF |
| 3 | DOUT1, Jin8/1, Jout8/9 | DIN/DOUT | C124391 | 649-1012938391001ALF |
| 1 | IC1 | 74HC595 | C5947 | 595-SN74HC595DR |
| 2 | IC5, IC6 | 74HC165 | C5613 | 595-SN74HC165DRG3 |
| 18 | R1-R18 | 10K | C25744 | 303-0402WGF1002TCE |
| 8 | R19-R26 | 220 | C25294 |
To Do
waiting for the assembled Prototype
Community users working on it
doutx2dinx1.1673226612.txt.gz · Last modified: 2023/01/09 01:10 by phatline
