dseq32_matrix
This page will contain the information about the combined lcd/button matrix forum topicuCApps
right now I'm using a modified version of the sm_simple C example
this code will be rewritten to make it more coherent
modifications to scan matrix example uCApps
Hardware
DOUT wiring
DIN wiring
*note: schematics not finished!
Software
in main.c:
//second shiftregister drives the leds
#define LEDOUT 1
void LM_SetRow(){
	MIOS_DOUT_SRSet(LEDOUT,ledtest[sm_col]);
// This function is called by MIOS before the shift register are loaded
void SR_Service_Prepare(void) __wparam
  // call the Scan Matrix Driver
  SM_PrepareCol();
  // call the Led Matrix Driver
  LM_SetRow();
in sm_simple.asm:
	global	_sm_button_column
	global	_sm_button_row
	global	_sm_button_value
	global  _sm_col
	;; import lables
	extern	_SM_NotifyToggle
accessram		udata		; (no access ram required, these variables can be located anywhere)
_sm_button_column	res	1	; exported to C, therefore an "_" has been added
_sm_button_row		res	1
_sm_button_value	res	1
_sm_col				res 1
SM_PrepareCol
	;; select next DOUT register
	;; (current column + 1) & 0x07
	SET_BSR	sm_selected_column
	incf	sm_selected_column, W, BANKED	; (* see note below)
	andlw	0x07
	;_sm_col is used by LM_SetRow()
	movwf	_sm_col
	call	MIOS_HLP_GetBitANDMask	; (inverted 1 of 8 code)
and finally in sm_simple.h:
extern unsigned char sm_button_value;
extern unsigned char sm_col;
Appendum
To avoid flickering leds when pushing a button the MIOS button debouncing should be turned off!!
Due to the setup of the SRIO driver the debounce algoritm also delays the DOUT chain when a DIN event is being debounced. So when a button is pushed the led update frequency is reduced, the higher the debounce value, the lower the update frequency.
According to this post TK will fix this in a future MIOS release:
This is something what I'm planning to solve in one of the next MIOS versions - currently the same SR scanning routine is used for DIN and DOUT registers, which means, >when the DINs are temporary disabled due to the cheap debouncing method, the DOUT registers won't be updated.
The solution is to add a second scan routine which only services the DOUTs so long the debouncing delay is active.
Workaround
To turn the debouncing off, set
#define DIN_DEBOUNCE_VALUE    0
back to DSEQ32
dseq32_matrix.1156334470.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
