fadercore_-_vlr-case
FadecoreFadercore
Casing
I desided to make a 2mm Aluminium bent case that supports the VLR-Frontpanel exactly. It will also have Holes to plug in the needed connections to my system. There will be a Network Connection for the use of RTP-Midi Module, 3.5mm Jack, MicroUSB Host, and a 220V T13 Plug to Power all that equipment inside. That brings me to the need of Powersupplies. I use two different supplies one 5V and one 12V both ordered my Mouser:
fadercore_-_vlr-case.1410550643.txt.gz · Last modified: 2014/09/12 19:37 by novski
