ju_control_roland_alpha_juno_control_panel_cs
MIDIBox Juno Control (JuCtrl)
Project Description
The MIDIBox JuCtrl is a Alpha Juno MIDI Controller https://en.wikipedia.org/wiki/Roland_Alpha_Juno. It's an additional control surface and MIDI Controller for the Roland Alpha Juno Synthesizer. I started this Project because the original Juno User CS is very minimalistic (80s Style). With the MIDIbox JuCtrl is every Tone parameter directly at hand. Furthermore you can store 8x all 128 Juno Tone Colours on 8 Banksticks.
Functions
  • Control every Juno Tone Parameter with an encoder or button
  • Control one parameter (Juno IPR Sysex) or send all parameter at once (Juno APR Sysex)
  • Store Juno patches (Tones) on Bankstick (Juno BLD Sysex)
  • Have a clearly arranged parameter overview (via CS LCD & LED)
  • MIDI processing: MIDI CC to Juno Sysex conversation (and Juno Sysex to MIDI CC conversation)
  • Use some extra Envelope functions (set all Envelope leve/time parameter to min or max & manipulate all time or level parameter at once with an encoder)
Hardware
JuCtrl Hardware:
Details
Notes
  • Note: Set SYSEX ON @AlphaJuno (JuCtrl will not work if SYSEX = off)
  • Note: JuCtrl CS will pick up all the TONE (Sound) Parameters automatically - if you make changes @Alpha Juno
  • Note: HOW TO SET JUNO SYSEX ON
    1. @Alpha Juno: Push the [MIDI] Button as many times until the MIDI SYSEX OPTION “MIDI EXCL” appears.
    2. Use the dial for changing.
    3. By writing the data of the MIDI Function setting into the back-up memory, it can be retained even when the Juno is turned off:
      • set the Memory Protect Switch to OFF position. Push the MIDI Button.
      • While holding the Write Button down, push the MIDI Button. The Juno Display will change to: “Write MIDI FUNC.”
      • When the MIDI Button is pushed: “Write Complete!”
  • Note: WRITE JUNO TONE DATA TO BANKSTICK
    1. SELECT THE PREFERRED BANKSTICK (1-8) with [SELECT BANKSTICK] BUTTON and [VALUE] ENCODER
    2. SELECT YOUR PREFERRED BANKSTICK AREA with the [MIDI ProgChange] ENCODER
    • MIDI ProgChange = 1-64 = You will WRITE Juno Tone Colours to BANKSTICK 1 -64
    • MIDI ProgChange = 65-128 = You will WRITE Juno Tone Colours TO BANKSTICK 65 -128
    1. Set [PRESET] (64x PRESET TONE COLOURS) or [MEMORY] (64x MEMORY TONE COLOURS) @Alpha Juno
    2. PRESS: [DATA TRANFERE] + [WRITE] + [DUMP] @Alpha Juno
    3. Now JuCtrl will RECEIVE 64 TONE COLOURS via SYSEX-DATA and write 64x TONE PATCHES to your selected BANKSTICK.
    • All Done.
    • BROWNS THE STORED TONE COLOURS with the “SELECT BANKSTICK TONE” ENCODER (0-127)
    • THE TONE NAME WILL APPEAR ON THE JuCtrl LCD. LOAD A STORED TONE COLOUR WITH THE BUTTON “SEND TONE TO CS”
    • NOW THE CS IS LOADED.
    • PRESS [SEND TONE TO JUNO] BUTTON for WRITING THE CURRENT CS DATA BACK TO ALPHA JUNO
  • Note: ENVELOPE FUNCTIONS
    • There are some ENVELOPE FUNCTIONS:
    1. LEVEL MAX: set all ENVELOPE LEVEL to max value (127)
    2. LEVEL MIN: set all ENVELOPE LEVEL to min value (0)
    3. ENVELOPE TIME MAX: set all ENVELOPE TIME PARAMETER to max value (127)
    4. ENVELOPE TIME MIN: set all ENVELOPE TIME PARAMETER to min value (0)
    5. IF YOUR LAST ACTION (@CS) WAS AN ENVELOPE MANIPULATION, YOU CAN MANIPULATE ALL TIME or LEVEL PARAMETER with the [VALUE] ENCODER
ProgChange
  • Juno ProgChange & JuCtrl Bankstick TONE (overview)
JuCtrl MIDI Juno Alpha Juno JuCtrl BANKSTICK (1-8)
LCD ProgCh BANK NUMBER GROUP TONE BS content BS content BS content
1 0 1 1 MEMORY 0 MEMORY 1 1 or PRESET 1 1 or USER SAVED “JuCtrl CS”
2 1 1 2 MEMORY 1 MEMORY 1 2 or PRESET 1 2 or USER SAVED “JuCtrl CS”
3 2 1 3 MEMORY 2 MEMORY 1 3 or PRESET 1 3 or USER SAVED “JuCtrl CS”
4 3 1 4 MEMORY 3 MEMORY 1 4 or PRESET 1 4 or USER SAVED “JuCtrl CS”
5 4 1 5 MEMORY 4 MEMORY 1 5 or PRESET 1 5 or USER SAVED “JuCtrl CS”
6 5 1 6 MEMORY 5 MEMORY 1 6 or PRESET 1 6 or USER SAVED “JuCtrl CS”
7 6 1 7 MEMORY 6 MEMORY 1 7 or PRESET 1 7 or USER SAVED “JuCtrl CS”
8 7 1 8 MEMORY 7 MEMORY 1 8 or PRESET 1 8 or USER SAVED “JuCtrl CS”
9 8 2 1 MEMORY 8 MEMORY 2 1 or PRESET 2 1 or USER SAVED “JuCtrl CS”
10 9 2 2 MEMORY 9 MEMORY 2 2 or PRESET 2 2 or USER SAVED “JuCtrl CS”
11 10 2 3 MEMORY 10 MEMORY 2 3 or PRESET 2 3 or USER SAVED “JuCtrl CS”
12 11 2 4 MEMORY 11 MEMORY 2 4 or PRESET 2 4 or USER SAVED “JuCtrl CS”
13 12 2 5 MEMORY 12 MEMORY 2 5 or PRESET 2 5 or USER SAVED “JuCtrl CS”
14 13 2 6 MEMORY 13 MEMORY 2 6 or PRESET 2 6 or USER SAVED “JuCtrl CS”
15 14 2 7 MEMORY 14 MEMORY 2 7 or PRESET 2 7 or USER SAVED “JuCtrl CS”
16 15 2 8 MEMORY 15 MEMORY 2 8 or PRESET 2 8 or USER SAVED “JuCtrl CS”
17 16 3 1 MEMORY 16 MEMORY 3 1 or PRESET 3 1 or USER SAVED “JuCtrl CS”
18 17 3 2 MEMORY 17 MEMORY 3 2 or PRESET 3 2 or USER SAVED “JuCtrl CS”
19 18 3 3 MEMORY 18 MEMORY 3 3 or PRESET 3 3 or USER SAVED “JuCtrl CS”
20 19 3 4 MEMORY 19 MEMORY 3 4 or PRESET 3 4 or USER SAVED “JuCtrl CS”
21 20 3 5 MEMORY 20 MEMORY 3 5 or PRESET 3 5 or USER SAVED “JuCtrl CS”
22 21 3 6 MEMORY 21 MEMORY 3 6 or PRESET 3 6 or USER SAVED “JuCtrl CS”
23 22 3 7 MEMORY 22 MEMORY 3 7 or PRESET 3 7 or USER SAVED “JuCtrl CS”
24 23 3 8 MEMORY 23 MEMORY 3 8 or PRESET 3 8 or USER SAVED “JuCtrl CS”
25 24 4 1 MEMORY 24 MEMORY 4 1 or PRESET 4 1 or USER SAVED “JuCtrl CS”
26 25 4 2 MEMORY 25 MEMORY 4 2 or PRESET 4 2 or USER SAVED “JuCtrl CS”
27 26 4 3 MEMORY 26 MEMORY 4 3 or PRESET 4 3 or USER SAVED “JuCtrl CS”
28 27 4 4 MEMORY 27 MEMORY 4 4 or PRESET 4 4 or USER SAVED “JuCtrl CS”
29 28 4 5 MEMORY 28 MEMORY 4 5 or PRESET 4 5 or USER SAVED “JuCtrl CS”
30 29 4 6 MEMORY 29 MEMORY 4 6 or PRESET 4 6 or USER SAVED “JuCtrl CS”
31 30 4 7 MEMORY 30 MEMORY 4 7 or PRESET 4 7 or USER SAVED “JuCtrl CS”
32 31 4 8 MEMORY 31 MEMORY 4 8 or PRESET 4 8 or USER SAVED “JuCtrl CS”
33 32 5 1 MEMORY 32 MEMORY 5 1 or PRESET 5 1 or USER SAVED “JuCtrl CS”
34 33 5 2 MEMORY 33 MEMORY 5 2 or PRESET 5 2 or USER SAVED “JuCtrl CS”
35 34 5 3 MEMORY 34 MEMORY 5 3 or PRESET 5 3 or USER SAVED “JuCtrl CS”
36 35 5 4 MEMORY 35 MEMORY 5 4 or PRESET 5 4 or USER SAVED “JuCtrl CS”
37 36 5 5 MEMORY 36 MEMORY 5 5 or PRESET 5 5 or USER SAVED “JuCtrl CS”
38 37 5 6 MEMORY 37 MEMORY 5 6 or PRESET 5 6 or USER SAVED “JuCtrl CS”
39 38 5 7 MEMORY 38 MEMORY 5 7 or PRESET 5 7 or USER SAVED “JuCtrl CS”
40 39 5 8 MEMORY 39 MEMORY 5 8 or PRESET 5 8 or USER SAVED “JuCtrl CS”
41 40 6 1 MEMORY 40 MEMORY 6 1 or PRESET 6 1 or USER SAVED “JuCtrl CS”
42 41 6 2 MEMORY 41 MEMORY 6 2 or PRESET 6 2 or USER SAVED “JuCtrl CS”
43 42 6 3 MEMORY 42 MEMORY 6 3 or PRESET 6 3 or USER SAVED “JuCtrl CS”
44 43 6 4 MEMORY 43 MEMORY 6 4 or PRESET 6 4 or USER SAVED “JuCtrl CS”
45 44 6 5 MEMORY 44 MEMORY 6 5 or PRESET 6 5 or USER SAVED “JuCtrl CS”
46 45 6 6 MEMORY 45 MEMORY 6 6 or PRESET 6 6 or USER SAVED “JuCtrl CS”
47 46 6 7 MEMORY 46 MEMORY 6 7 or PRESET 6 7 or USER SAVED “JuCtrl CS”
48 47 6 8 MEMORY 47 MEMORY 6 8 or PRESET 6 8 or USER SAVED “JuCtrl CS”
49 48 7 1 MEMORY 48 MEMORY 7 1 or PRESET 7 1 or USER SAVED “JuCtrl CS”
50 49 7 2 MEMORY 49 MEMORY 7 2 or PRESET 7 2 or USER SAVED “JuCtrl CS”
51 50 7 3 MEMORY 50 MEMORY 7 3 or PRESET 7 3 or USER SAVED “JuCtrl CS”
52 51 7 4 MEMORY 51 MEMORY 7 4 or PRESET 7 4 or USER SAVED “JuCtrl CS”
53 52 7 5 MEMORY 52 MEMORY 7 5 or PRESET 7 5 or USER SAVED “JuCtrl CS”
54 53 7 6 MEMORY 53 MEMORY 7 6 or PRESET 7 6 or USER SAVED “JuCtrl CS”
55 54 7 7 MEMORY 54 MEMORY 7 7 or PRESET 7 7 or USER SAVED “JuCtrl CS”
56 55 7 8 MEMORY 55 MEMORY 7 8 or PRESET 7 8 or USER SAVED “JuCtrl CS”
57 56 8 1 MEMORY 56 MEMORY 8 1 or PRESET 8 1 or USER SAVED “JuCtrl CS”
58 57 8 2 MEMORY 57 MEMORY 8 2 or PRESET 8 2 or USER SAVED “JuCtrl CS”
59 58 8 3 MEMORY 58 MEMORY 8 3 or PRESET 8 3 or USER SAVED “JuCtrl CS”
60 59 8 4 MEMORY 59 MEMORY 8 4 or PRESET 8 4 or USER SAVED “JuCtrl CS”
61 60 8 5 MEMORY 60 MEMORY 8 5 or PRESET 8 5 or USER SAVED “JuCtrl CS”
62 61 8 6 MEMORY 61 MEMORY 8 6 or PRESET 8 6 or USER SAVED “JuCtrl CS”
63 62 8 7 MEMORY 62 MEMORY 8 7 or PRESET 8 7 or USER SAVED “JuCtrl CS”
64 63 8 8 MEMORY 63 MEMORY 8 8 or PRESET 8 8 or USER SAVED “JuCtrl CS”
65 64 1 1 PRESET 64 PRESET 1 1 or MEMORY 1 1 or USER SAVED “JuCtrl CS”
66 65 1 2 PRESET 65 PRESET 1 2 or MEMORY 1 2 or USER SAVED “JuCtrl CS”
67 66 1 3 PRESET 66 PRESET 1 3 or MEMORY 1 3 or USER SAVED “JuCtrl CS”
68 67 1 4 PRESET 67 PRESET 1 4 or MEMORY 1 4 or USER SAVED “JuCtrl CS”
69 68 1 5 PRESET 68 PRESET 1 5 or MEMORY 1 5 or USER SAVED “JuCtrl CS”
70 69 1 6 PRESET 69 PRESET 1 6 or MEMORY 1 6 or USER SAVED “JuCtrl CS”
71 70 1 7 PRESET 70 PRESET 1 7 or MEMORY 1 7 or USER SAVED “JuCtrl CS”
72 71 1 8 PRESET 71 PRESET 1 8 or MEMORY 1 8 or USER SAVED “JuCtrl CS”
73 72 2 1 PRESET 72 PRESET 2 1 or MEMORY 2 1 or USER SAVED “JuCtrl CS”
74 73 2 2 PRESET 73 PRESET 2 2 or MEMORY 2 2 or USER SAVED “JuCtrl CS”
75 74 2 3 PRESET 74 PRESET 2 3 or MEMORY 2 3 or USER SAVED “JuCtrl CS”
76 75 2 4 PRESET 75 PRESET 2 4 or MEMORY 2 4 or USER SAVED “JuCtrl CS”
77 76 2 5 PRESET 76 PRESET 2 5 or MEMORY 2 5 or USER SAVED “JuCtrl CS”
78 77 2 6 PRESET 77 PRESET 2 6 or MEMORY 2 6 or USER SAVED “JuCtrl CS”
79 78 2 7 PRESET 78 PRESET 2 7 or MEMORY 2 7 or USER SAVED “JuCtrl CS”
80 79 2 8 PRESET 79 PRESET 2 8 or MEMORY 2 8 or USER SAVED “JuCtrl CS”
81 80 3 1 PRESET 80 PRESET 3 1 or MEMORY 3 1 or USER SAVED “JuCtrl CS”
82 81 3 2 PRESET 81 PRESET 3 2 or MEMORY 3 2 or USER SAVED “JuCtrl CS”
83 82 3 3 PRESET 82 PRESET 3 3 or MEMORY 3 3 or USER SAVED “JuCtrl CS”
84 83 3 4 PRESET 83 PRESET 3 4 or MEMORY 3 4 or USER SAVED “JuCtrl CS”
85 84 3 5 PRESET 84 PRESET 3 5 or MEMORY 3 5 or USER SAVED “JuCtrl CS”
86 85 3 6 PRESET 85 PRESET 3 6 or MEMORY 3 6 or USER SAVED “JuCtrl CS”
87 86 3 7 PRESET 86 PRESET 3 7 or MEMORY 3 7 or USER SAVED “JuCtrl CS”
88 87 3 8 PRESET 87 PRESET 3 8 or MEMORY 3 8 or USER SAVED “JuCtrl CS”
89 88 4 1 PRESET 88 PRESET 4 1 or MEMORY 4 1 or USER SAVED “JuCtrl CS”
90 89 4 2 PRESET 89 PRESET 4 2 or MEMORY 4 2 or USER SAVED “JuCtrl CS”
91 90 4 3 PRESET 90 PRESET 4 3 or MEMORY 4 3 or USER SAVED “JuCtrl CS”
92 91 4 4 PRESET 91 PRESET 4 4 or MEMORY 4 4 or USER SAVED “JuCtrl CS”
93 92 4 5 PRESET 92 PRESET 4 5 or MEMORY 4 5 or USER SAVED “JuCtrl CS”
94 93 4 6 PRESET 93 PRESET 4 6 or MEMORY 4 6 or USER SAVED “JuCtrl CS”
95 94 4 7 PRESET 94 PRESET 4 7 or MEMORY 4 7 or USER SAVED “JuCtrl CS”
96 95 4 8 PRESET 95 PRESET 4 8 or MEMORY 4 8 or USER SAVED “JuCtrl CS”
97 96 5 1 PRESET 96 PRESET 5 1 or MEMORY 5 1 or USER SAVED “JuCtrl CS”
98 97 5 2 PRESET 97 PRESET 5 2 or MEMORY 5 2 or USER SAVED “JuCtrl CS”
99 98 5 3 PRESET 98 PRESET 5 3 or MEMORY 5 3 or USER SAVED “JuCtrl CS”
100 99 5 4 PRESET 99 PRESET 5 4 or MEMORY 5 4 or USER SAVED “JuCtrl CS”
101 100 5 5 PRESET 100 PRESET 5 5 or MEMORY 5 5 or USER SAVED “JuCtrl CS”
102 101 5 6 PRESET 101 PRESET 5 6 or MEMORY 5 6 or USER SAVED “JuCtrl CS”
103 102 5 7 PRESET 102 PRESET 5 7 or MEMORY 5 7 or USER SAVED “JuCtrl CS”
104 103 5 8 PRESET 103 PRESET 5 8 or MEMORY 5 8 or USER SAVED “JuCtrl CS”
105 104 6 1 PRESET 104 PRESET 6 1 or MEMORY 6 1 or USER SAVED “JuCtrl CS”
106 105 6 2 PRESET 105 PRESET 6 2 or MEMORY 6 2 or USER SAVED “JuCtrl CS”
107 106 6 3 PRESET 106 PRESET 6 3 or MEMORY 6 3 or USER SAVED “JuCtrl CS”
108 107 6 4 PRESET 107 PRESET 6 4 or MEMORY 6 4 or USER SAVED “JuCtrl CS”
109 108 6 5 PRESET 108 PRESET 6 5 or MEMORY 6 5 or USER SAVED “JuCtrl CS”
110 109 6 6 PRESET 109 PRESET 6 6 or MEMORY 6 6 or USER SAVED “JuCtrl CS”
111 110 6 7 PRESET 110 PRESET 6 7 or MEMORY 6 7 or USER SAVED “JuCtrl CS”
112 111 6 8 PRESET 111 PRESET 6 8 or MEMORY 6 8 or USER SAVED “JuCtrl CS”
113 112 7 1 PRESET 112 PRESET 7 1 or MEMORY 7 1 or USER SAVED “JuCtrl CS”
114 113 7 2 PRESET 113 PRESET 7 2 or MEMORY 7 2 or USER SAVED “JuCtrl CS”
115 114 7 3 PRESET 114 PRESET 7 3 or MEMORY 7 3 or USER SAVED “JuCtrl CS”
116 115 7 4 PRESET 115 PRESET 7 4 or MEMORY 7 4 or USER SAVED “JuCtrl CS”
117 116 7 5 PRESET 116 PRESET 7 5 or MEMORY 7 5 or USER SAVED “JuCtrl CS”
118 117 7 6 PRESET 117 PRESET 7 6 or MEMORY 7 6 or USER SAVED “JuCtrl CS”
119 118 7 7 PRESET 118 PRESET 7 7 or MEMORY 7 7 or USER SAVED “JuCtrl CS”
120 119 7 8 PRESET 119 PRESET 7 8 or MEMORY 7 8 or USER SAVED “JuCtrl CS”
121 120 8 1 PRESET 120 PRESET 8 1 or MEMORY 8 1 or USER SAVED “JuCtrl CS”
122 121 8 2 PRESET 121 PRESET 8 2 or MEMORY 8 2 or USER SAVED “JuCtrl CS”
123 122 8 3 PRESET 122 PRESET 8 3 or MEMORY 8 3 or USER SAVED “JuCtrl CS”
124 123 8 4 PRESET 123 PRESET 8 4 or MEMORY 8 4 or USER SAVED “JuCtrl CS”
125 124 8 5 PRESET 124 PRESET 8 5 or MEMORY 8 5 or USER SAVED “JuCtrl CS”
126 125 8 6 PRESET 125 PRESET 8 6 or MEMORY 8 6 or USER SAVED “JuCtrl CS”
127 126 8 7 PRESET 126 PRESET 8 7 or MEMORY 8 7 or USER SAVED “JuCtrl CS”
128 127 8 8 PRESET 127 PRESET 8 8 or MEMORY 8 8 or USER SAVED “JuCtrl CS”
Project Status
09/2012
|| --- Project Start [28 October 2011]:
|| --- 100% JuCtrl MBHP DIN, DOUT, LCD, ENC
|| --- 100% MBHP IIC MIDI Module (one extra MIDI IO for Juno)
|| --- 100% CC MIDI IN --->[Ju Control (MIDI CC to SYSEX Conversation)] --->MIDI OUT--->[Juno]
|| --- 100% Program Change (Sound Patch) via CS ENC
|| --- 100% Send Individual CS Controller Values to Juno (Juno IPR-Mode SYSEX, CC)
|| --- 100% Receive Individual Tone Parameters from Juno (Juno IPR-Mode SYSEX)
|| --- 100% Send All CS Tone Parameters to Juno (Juno APR-Mode Sysex)
|| --- 100% Receive All Tone Parameters from Juno(Juno APR-Mode Sysex)
|| --- 100% HW: Update Core8 >> PIC18F4620 (Need more Program Memory and SRAM for BLD-Mode Sysex Data)
|| --- 100% Bankstick (BS 1-8 = 8*128 Tone Patches)
|| --- 100% ENVELOPE functions (BTN F1-F4)
|| --- 100% Send Bankstick sysex-dump (Tone Backup)
Software
Links
ju_control_roland_alpha_juno_control_panel_cs.1346874976.txt.gz · Last modified: 2012/09/05 19:56 by lemonhorse
