====== LRE8x2 096 SSD1306-BAR for Eurorack V2 ====== {{:phatline:LRE-OLED-BAR2-3D-Front.jpg?600|}}\\ {{:phatline:LRE-OLED-BAR2-Frontpanel.jpg?900|}}\\ **I made this PCBs to use it with Fairlightii´s [[mb-lre8x2cs_pcb]]**\\ **PCB**\\ I didnt panalize it, so you have to do this when ordering the PCB online\\ you will need 4 PCBs per LRE8x2... normally you want to order 8 PCBs (using 2x LRE8x2)\\ {{:phatline:LRE-OLED-BAR-PCB-Front.jpg?500|}}\\ Here are the gerberfiles for production - i made it with[[https://jlcpcb.com/|JLCPCB]]\\ {{:phatline:LRE-OLED-BAR2-Gerber.zip?900|}}\\ {{:phatline:JLCPCB-low-cost.jpg?476|}}\\ ====== Hardware Requirements ====== * [[http://www.ucapps.de/mbhp_core_stm32f4.html]]a MIOS32 Core to connect too\\ * [[DisplayDriver-SMD]] which buffers the Displays * Soldering Iron - with a Dip that can Handle Thruhole-Parts, solder Paste...\\ * [[mb-lre8x2cs_pcb]] for its nature use\\ * [[LRE5-LCD2]] as UI to handle Patch management and automation (if you want to use my code...) ====== Shematic ====== {{:phatline:LRE-OLED-BAR2-Shematic.jpg?400|}}\\ ====== Building and BOM====== {{:phatline:LRE-OLED-BAR2-3D-Back.jpg?700|}}\\ **Following Quantity is for 1 PCB (you may need this up to 8 times!:**\\ 2x 1Row 7Pin Male headers (2.54mm pitch) - normally delivered with the Displays!\\ 2x 8PIN Ribbon Connectors (2x4Pin Female) + Cables [[https://eu.mouser.com/ProductDetail/Wurth-Elektronik/61200823021?qs=PhR8RmCirEZvQm5v3EiYrA%3D%3D]]\\ 2x 8PIN Ribbon Terminals (2x4Pin Male) SMD Variant [[https://jlcpcb.com/partdetail/boomele_boom_Precision_elec-C192300/C192300]]\\ 2x 0.96" SSD1306 Screens 7Pin Variant! i recommend white ones [[https://www.aliexpress.com/item/32638662748.html?spm=a2g0o.order_list.order_list_main.10.21ef1802NuwRWb|at Ali express]]\\ {{:phatline:LRE-OLED-BAR2-3D-Perspektive.jpg?700|}}\\ ====== Frontpanel====== {{:phatline:LRE-OLED-BAR2-Frontpanel-BILD.jpg?700|}}\\ I made a DXF File which you can send to [[https://www.formulor.de/|Formulor in Germany]]\\ i panalized it so there are 2 Plates in it\\ I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ {{:phatline:LRE-OLED-BAR2-FP-FORMULAR.zip?700|}}\\ **Recommend Material from Formulor:**\\ 3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ ====== To Do ====== The LRE-OLED-Bar & The Frontpanel are a Part of my [[MSQ-CC-LRE-V2]]\\ so look there for more information.... ====== Community users working on it ====== * **[[Phatline]]** = PCB & Shematic, UI-Programming, Documentation...\\ Just let a Private message on the forum to user already involved.\\
