ssm2044_pcb_bulk_order
                Dual SSM 2044 PCB Bulk Order
This page is about Seppoman's bulk order for the ssm2044_pcb.
More information and sound demos can be found here and here.
Warning: This is not a suitable project for absolute beginners. The soldering isn't very difficult, but you will need either an AOUT_NG (SMT soldering required), an AOUT module (which needs to be expanded with the bipolar option) or two (!) AOUT_LC modules, or another type of CV source to control this module, in addition to the actual synth (SID/FM) you want to use it with. So a bit of soldering experience and knowledge about the MidiBox platform is definitely recommended.
ssm2044_pcb_bulk_order.txt · Last modified: 2010/03/11 08:38 by seppoman
