Defines |
| #define  | DEBUG_VERBOSE_LEVEL   1 |
| #define  | SECTOR_SIZE   _MAX_SS |
| #define  | TMP_BUFFER_SIZE   _MAX_SS |
Functions |
| s32  | FILE_Init (u32 mode) |
| s32  | FILE_CheckSDCard (void) |
| s32  | FILE_UpdateFreeBytes (void) |
| u32  | FILE_VolumeSectorsPerCluster (void) |
| u32  | FILE_VolumeCluster2Sector (u32 cluster) |
| s32  | FILE_SDCardAvailable (void) |
| s32  | FILE_VolumeAvailable (void) |
| u32  | FILE_VolumeBytesFree (void) |
| u32  | FILE_VolumeBytesTotal (void) |
| char *  | FILE_VolumeLabel (void) |
| s32  | FILE_ReadOpen (file_t *file, char *filepath) |
| s32  | FILE_ReadReOpen (file_t *file) |
| s32  | FILE_ReadClose (file_t *file) |
| s32  | FILE_ReadSeek (u32 offset) |
| u32  | FILE_ReadGetCurrentSize (void) |
| u32  | FILE_ReadGetCurrentPosition (void) |
| s32  | FILE_ReadBuffer (u8 *buffer, u32 len) |
| s32  | FILE_ReadBufferUnknownLen (u8 *buffer, u32 len) |
| s32  | FILE_ReadLine (u8 *buffer, u32 max_len) |
| s32  | FILE_ReadByte (u8 *byte) |
| s32  | FILE_ReadHWord (u16 *hword) |
| s32  | FILE_ReadWord (u32 *word) |
| s32  | FILE_WriteOpen (char *filepath, u8 create) |
| s32  | FILE_WriteClose (void) |
| s32  | FILE_WriteSeek (u32 offset) |
| u32  | FILE_WriteGetCurrentSize (void) |
| u32  | FILE_WriteGetCurrentPosition (void) |
| s32  | FILE_WriteBuffer (u8 *buffer, u32 len) |
| s32  | FILE_WriteByte (u8 byte) |
| s32  | FILE_WriteHWord (u16 hword) |
| s32  | FILE_WriteWord (u32 word) |
| s32  | FILE_Copy (char *src_file, char *dst_file) |
| s32  | FILE_MakeDir (char *path) |
| s32  | FILE_Remove (char *path) |
| s32  | FILE_FileExists (char *filepath) |
| s32  | FILE_DirExists (char *path) |
| s32  | FILE_GetDirs (char *path, char *dir_list, u8 num_of_items, u8 dir_offset) |
| s32  | FILE_GetFiles (char *path, char *ext_filter, char *file_list, u8 num_of_items, u8 file_offset) |
| s32  | FILE_FindNextFile (char *path, char *filename, char *ext_filter, char *next_filename) |
| s32  | FILE_FindPreviousFile (char *path, char *filename, char *ext_filter, char *prev_filename) |
| s32  | FILE_SendSyxDump (char *path, mios32_midi_port_t port, u32 ms_delay_between_dumps) |
| s32  | FILE_PrintSDCardInfos (void) |
| s32  | FILE_SendErrorMessage (s32 error_status) |
| s32  | FILE_BrowserHandler (mios32_midi_port_t port, char *command) |
| s32  | FILE_BrowserUploadCallback_Init (s32(*callback_upload)(char *filename)) |
Variables |
| u32  | file_dfs_errno |
| u8  | file_copy_percentage |
