#include <mios32.h>#include <usbd_core.h>#include <usbd_def.h>#include <usbd_desc.h>#include <usbd_req.h>#include <usbd_conf.h>#include <usbh_core.h>#include <usbh_conf.h>#include <usb_otg.h>#include <usb_dcd_int.h>#include <usb_hcd_int.h>#include <usb_regs.h>#include <string.h>Defines | |
| #define | DSCR_DEVICE 1 |
| #define | DSCR_CONFIG 2 |
| #define | DSCR_STRING 3 |
| #define | DSCR_INTRFC 4 |
| #define | DSCR_ENDPNT 5 |
| #define | CS_INTERFACE 0x24 |
| #define | CS_ENDPOINT 0x25 |
| #define | MIOS32_USB_MIDI_NUM_INTERFACES 2 |
| #define | MIOS32_USB_MIDI_AC_INTERFACE_IX 0x00 |
| #define | MIOS32_USB_MIDI_AS_INTERFACE_IX 0x01 |
| #define | MIOS32_USB_MIDI_INTERFACE_OFFSET 2 |
| #define | MIOS32_USB_MIDI_SIZ_CLASS_DESC (7+MIOS32_USB_MIDI_NUM_PORTS*(6+6+9+9)+9+(4+MIOS32_USB_MIDI_NUM_PORTS)+9+(4+MIOS32_USB_MIDI_NUM_PORTS)) |
| #define | MIOS32_USB_MIDI_SIZ_CONFIG_DESC (9+MIOS32_USB_MIDI_USE_AC_INTERFACE*(9+9)+MIOS32_USB_MIDI_SIZ_CLASS_DESC) |
| #define | MIOS32_USB_MIDI_SIZ_CLASS_DESC_SINGLE_USB (7+1*(6+6+9+9)+9+(4+1)+9+(4+1)) |
| #define | MIOS32_USB_MIDI_SIZ_CONFIG_DESC_SINGLE_USB (9+MIOS32_USB_MIDI_USE_AC_INTERFACE*(9+9)+MIOS32_USB_MIDI_SIZ_CLASS_DESC) |
| #define | MIOS32_USB_COM_NUM_INTERFACES 2 |
| #define | MIOS32_USB_COM_SIZ_CONFIG_DESC 58 |
| #define | MIOS32_USB_COM_CC_INTERFACE_IX (MIOS32_USB_MIDI_INTERFACE_OFFSET + 0x00) |
| #define | MIOS32_USB_COM_CD_INTERFACE_IX (MIOS32_USB_MIDI_INTERFACE_OFFSET + 0x01) |
| #define | MIOS32_USB_COM_INTERFACE_OFFSET (MIOS32_USB_MIDI_INTERFACE_OFFSET + 2) |
| #define | MIOS32_USB_NUM_INTERFACES (MIOS32_USB_MIDI_NUM_INTERFACES + MIOS32_USB_COM_NUM_INTERFACES) |
| #define | MIOS32_USB_SIZ_CONFIG_DESC (9 + MIOS32_USB_MIDI_SIZ_CONFIG_DESC + MIOS32_USB_COM_SIZ_CONFIG_DESC) |
| #define | MIOS32_USB_SIZ_CONFIG_DESC_SINGLE_USB (9 + MIOS32_USB_MIDI_SIZ_CONFIG_DESC_SINGLE_USB) |
| #define | MIOS32_USB_SIZ_DEVICE_DESC 18 |
Functions | |
| void | USB_OTG_BSP_Init (USB_OTG_CORE_HANDLE *pdev) |
| USB_OTG_BSP_Init Initilizes BSP configurations. | |
| void | USB_OTG_BSP_EnableInterrupt (USB_OTG_CORE_HANDLE *pdev) |
| USB_OTG_BSP_EnableInterrupt Enabele USB Global interrupt. | |
| void | OTG_FS_IRQHandler (void) |
| This function handles OTG_FS Handler. | |
| void | USB_OTG_BSP_uDelay (const uint32_t usec) |
| USB_OTG_BSP_uDelay This function provides delay time in micro sec. | |
| void | USB_OTG_BSP_mDelay (const uint32_t msec) |
| USB_OTG_BSP_mDelay This function provides delay time in milli sec. | |
| void | USB_OTG_BSP_ConfigVBUS (USB_OTG_CORE_HANDLE *pdev) |
| USB_OTG_BSP_ConfigVBUS Configures the IO for the Vbus and OverCurrent. | |
| void | USB_OTG_BSP_DriveVBUS (USB_OTG_CORE_HANDLE *pdev, uint8_t state) |
| BSP_Drive_VBUS Drives the Vbus signal through IO. | |
| s32 | MIOS32_USB_Init (u32 mode) |
| s32 | MIOS32_USB_IsInitialized (void) |
| s32 | MIOS32_USB_ForceSingleUSB (void) |
| s32 | MIOS32_USB_ForceDeviceMode (void) |
Variables | |
| __ALIGN_BEGIN USB_OTG_CORE_HANDLE USB_OTG_dev | __ALIGN_END |
| uint32_t | USB_rx_buffer [MIOS32_USB_MIDI_DATA_OUT_SIZE/4] |
| const USBH_Class_cb_TypeDef | MIOS32_MIDI_USBH_Callbacks |
1.6.1
