KEYBOARD
Defines
#define DEBUG_MSG   MIOS32_MIDI_SendDebugMessage
#define MATRIX_NUM_ROWS   16
#define KEYBOARD_NUM_PINS   (16*MATRIX_NUM_ROWS)
#define FANTOM_XR_VARIANT   0
Functions
s32 KEYBOARD_Init (u32 mode)
s32 KEYBOARD_ConnectedNumSet (u8 num)
u8 KEYBOARD_ConnectedNumGet (void)
void KEYBOARD_SRIO_ServicePrepare (void)
void KEYBOARD_SRIO_ServiceFinish (void)
void KEYBOARD_Periodic_1mS (void)
void KEYBOARD_AIN_NotifyChange (u32 pin, u32 pin_value)
s32 KEYBOARD_TerminalHelp (void *_output_function)
s32 KEYBOARD_TerminalParseLine (char *input, void *_output_function)
s32 KEYBOARD_TerminalPrintConfig (int kb, void *_output_function)
s32 KEYBOARD_TerminalPrintDelays (int kb, void *_output_function)
Variables
keyboard_config_t keyboard_config [KEYBOARD_NUM]
Detailed Description
Keyboard Handler
Define Documentation
Function Documentation
void KEYBOARD_AIN_NotifyChange ( u32  pin,
u32  pin_value
This function should be called from AIN_NotifyChange in app.c
In addition it should be called periodically from a task to handle the reduced bandwidth function.
See also apps/controllers/midibox_kb_v1/src/app.c
     // update AINs with current value
     // the keyboard driver will only send events on value changes
       int pin;
       for(pin=0; pin<8; ++pin) {
        KEYBOARD_AIN_NotifyChange(pin, MIOS32_AIN_PinGet(pin));
u8 KEYBOARD_ConnectedNumGet ( void   )
Returns number of connected keyboards
s32 KEYBOARD_ConnectedNumSet ( u8  num  )
Sets number of connected keyboards
s32 KEYBOARD_Init ( u32  mode  )
Initialize the keyboard handler
Parameters:
mode == 0: init configuration + runtime variables
mode > 0: init only runtime variables
void KEYBOARD_Periodic_1mS ( void   )
This function should be called periodically (each mS) to check for pin changes
void KEYBOARD_SRIO_ServiceFinish ( void   )
This hook is called after the shift register chain has been scanned
void KEYBOARD_SRIO_ServicePrepare ( void   )
This hook is called before the shift register chain is scanned
s32 KEYBOARD_TerminalHelp ( void *  _output_function  )
Returns help page for implemented terminal commands of this module
s32 KEYBOARD_TerminalParseLine ( char *  input,
Parser for a complete line
Returns:
> 0 if command line matches with UIP terminal commands
s32 KEYBOARD_TerminalPrintConfig ( int  kb,
Keyboard Configuration (can also be called from external)
s32 KEYBOARD_TerminalPrintDelays ( int  kb,
Variable Documentation
