Files | |
| file | uip_arch.h |
Functions | |
| void | uip_add32 (u8_t *op32, u16_t op16) |
| u16_t | uip_chksum (u16_t *buf, u16_t len) |
| u16_t | uip_ipchksum (void) |
| u16_t | uip_tcpchksum (void) |
| u16_t | uip_udpchksum (void) |
Variables | |
| u8_t | uip_acc32 [4] |
The functions in the architecture specific module implement the IP check sum and 32-bit additions.
The IP checksum calculation is the most computationally expensive operation in the TCP/IP stack and it therefore pays off to implement this in efficient assembler. The purpose of the uip-arch module is to let the checksum functions to be implemented in architecture specific assembler.
Carry out a 32-bit addition.
Because not all architectures for which uIP is intended has native 32-bit arithmetic, uIP uses an external C function for doing the required 32-bit additions in the TCP protocol processing. This function should add the two arguments and place the result in the global variable uip_acc32.
| op32 | A pointer to a 4-byte array representing a 32-bit integer in network byte order (big endian). | |
| op16 | A 16-bit integer in host byte order. |
Calculate the Internet checksum over a buffer.
The Internet checksum is the one's complement of the one's complement sum of all 16-bit words in the buffer.
See RFC1071.
| buf | A pointer to the buffer over which the checksum is to be computed. | |
| len | The length of the buffer over which the checksum is to be computed. |
See RFC1071.
| u16_t uip_ipchksum | ( | void | ) |
Calculate the IP header checksum of the packet header in uip_buf.
The IP header checksum is the Internet checksum of the 20 bytes of the IP header.
| u16_t uip_tcpchksum | ( | void | ) |
Calculate the TCP checksum of the packet in uip_buf and uip_appdata.
The TCP checksum is the Internet checksum of data contents of the TCP segment, and a pseudo-header as defined in RFC793.
| u16_t uip_udpchksum | ( | void | ) |
1.6.1
