The uIP TCP/IP stack
Collaboration diagram for The uIP TCP/IP stack:
Data Structures
struct  uip_conn
struct  uip_stats
struct  uip_tcpip_hdr
struct  uip_icmpip_hdr
struct  uip_udpip_hdr
struct  uip_eth_addr
Modules
 uIP packet forwarding
 uIP TCP throughput booster hack
 uIP configuration functions
 uIP initialization functions
 uIP device driver functions
 uIP application functions
 uIP conversion functions
 Variables used in uIP device drivers
 uIP Address Resolution Protocol
 Architecture specific uIP functions
Files
file  uip.c
file  uip.h
Defines
#define TCP_FIN   0x01
#define TCP_SYN   0x02
#define TCP_RST   0x04
#define TCP_PSH   0x08
#define TCP_ACK   0x10
#define TCP_URG   0x20
#define TCP_CTL   0x3f
#define TCP_OPT_END   0
#define TCP_OPT_NOOP   1
#define TCP_OPT_MSS   2
#define TCP_OPT_MSS_LEN   4
#define ICMP_ECHO_REPLY   0
#define ICMP_ECHO   8
#define ICMP6_ECHO_REPLY   129
#define ICMP6_ECHO   128
#define ICMP6_NEIGHBOR_SOLICITATION   135
#define ICMP6_NEIGHBOR_ADVERTISEMENT   136
#define ICMP6_FLAG_S   (1 << 6)
#define ICMP6_OPTION_SOURCE_LINK_ADDRESS   1
#define ICMP6_OPTION_TARGET_LINK_ADDRESS   2
#define BUF   ((struct uip_tcpip_hdr *)&uip_buf[UIP_LLH_LEN])
#define FBUF   ((struct uip_tcpip_hdr *)&uip_reassbuf[0])
#define ICMPBUF   ((struct uip_icmpip_hdr *)&uip_buf[UIP_LLH_LEN])
#define UDPBUF   ((struct uip_udpip_hdr *)&uip_buf[UIP_LLH_LEN])
#define UIP_STAT(s)
#define UIP_LOG(m)
#define UIP_ACKDATA   1
#define UIP_NEWDATA   2
#define UIP_REXMIT   4
#define UIP_POLL   8
#define UIP_CLOSE   16
#define UIP_ABORT   32
#define UIP_CONNECTED   64
#define UIP_TIMEDOUT   128
#define UIP_DATA   1
#define UIP_TIMER   2
#define UIP_POLL_REQUEST   3
#define UIP_UDP_SEND_CONN   4
#define UIP_CLOSED   0
#define UIP_SYN_RCVD   1
#define UIP_SYN_SENT   2
#define UIP_ESTABLISHED   3
#define UIP_FIN_WAIT_1   4
#define UIP_FIN_WAIT_2   5
#define UIP_CLOSING   6
#define UIP_TIME_WAIT   7
#define UIP_LAST_ACK   8
#define UIP_TS_MASK   15
#define UIP_STOPPED   16
#define UIP_APPDATA_SIZE
#define UIP_PROTO_ICMP   1
#define UIP_PROTO_TCP   6
#define UIP_PROTO_UDP   17
#define UIP_PROTO_ICMP6   58
#define UIP_IPH_LEN   20
#define UIP_UDPH_LEN   8
#define UIP_TCPH_LEN   20
#define UIP_IPUDPH_LEN   (UIP_UDPH_LEN + UIP_IPH_LEN)
#define UIP_IPTCPH_LEN   (UIP_TCPH_LEN + UIP_IPH_LEN)
#define UIP_TCPIP_HLEN   UIP_IPTCPH_LEN
Typedefs
typedef u16_t uip_ip4addr_t [2]
typedef u16_t uip_ip6addr_t [8]
typedef uip_ip4addr_t uip_ipaddr_t
Functions
void uip_setipid (u16_t id)
void uip_add32 (u8_t *op32, u16_t op16)
u16_t uip_chksum (u16_t *data, u16_t len)
u16_t uip_ipchksum (void)
u16_t uip_tcpchksum (void)
void uip_init (void)
void uip_unlisten (u16_t port)
void uip_listen (u16_t port)
void uip_process (u8_t flag)
u16_t htons (u16_t val)
void uip_send (const void *data, int len)
u16_t uip_udpchksum (void)
Variables
uip_ipaddr_t uip_hostaddr
uip_ipaddr_t uip_draddr
uip_ipaddr_t uip_netmask
struct uip_eth_addr uip_ethaddr = {{0,0,0,0,0,0}}
u8_t uip_buf [UIP_BUFSIZE+2]
void * uip_appdata
void * uip_sappdata
u16_t uip_len
u16_t uip_slen
u8_t uip_flags
struct uip_conn * uip_conn
struct uip_conn uip_conns [UIP_CONNS]
u16_t uip_listenports [UIP_LISTENPORTS]
u8_t uip_acc32 [4]
void * uip_appdata
struct uip_stats uip_stat
u8_t uip_flags
Detailed Description
uIP is an implementation of the TCP/IP protocol stack intended for small 8-bit and 16-bit microcontrollers.
uIP provides the necessary protocols for Internet communication, with a very small code footprint and RAM requirements - the uIP code size is on the order of a few kilobytes and RAM usage is on the order of a few hundred bytes.
Define Documentation
#define ICMP_ECHO   8
The buffer size available for user data in the uip_buf buffer.
This macro holds the available size for user data in the uip_buf buffer. The macro is intended to be used for checking bounds of available user data.
Example:
#define UIP_DATA   1
#define UIP_LOG ( m   )
#define UIP_POLL   8
#define UIP_STAT ( s   )
#define UIP_TIMER   2
Typedef Documentation
typedef u16_t uip_ip4addr_t[2]
Repressentation of an IP address.
typedef u16_t uip_ip6addr_t[8]
Function Documentation
u16_t htons ( u16_t  val  )
Convert 16-bit quantity from host byte order to network byte order.
This function is primarily used for converting variables from host byte order to network byte order. For converting constants to network byte order, use the HTONS() macro instead.
void uip_add32 ( u8_t *  op32,
u16_t  op16
Carry out a 32-bit addition.
Because not all architectures for which uIP is intended has native 32-bit arithmetic, uIP uses an external C function for doing the required 32-bit additions in the TCP protocol processing. This function should add the two arguments and place the result in the global variable uip_acc32.
Note:
The 32-bit integer pointed to by the op32 parameter and the result in the uip_acc32 variable are in network byte order (big endian).
Parameters:
op32 A pointer to a 4-byte array representing a 32-bit integer in network byte order (big endian).
op16 A 16-bit integer in host byte order.
u16_t uip_chksum ( u16_t *  buf,
u16_t  len
Calculate the Internet checksum over a buffer.
The Internet checksum is the one's complement of the one's complement sum of all 16-bit words in the buffer.
See RFC1071.
Parameters:
buf A pointer to the buffer over which the checksum is to be computed.
len The length of the buffer over which the checksum is to be computed.
Returns:
The Internet checksum of the buffer.
void uip_init ( void   )
uIP initialization function.
This function should be called at boot up to initilize the uIP TCP/IP stack.
u16_t uip_ipchksum ( void   )
Calculate the IP header checksum of the packet header in uip_buf.
The IP header checksum is the Internet checksum of the 20 bytes of the IP header.
Returns:
The IP header checksum of the IP header in the uip_buf buffer.
void uip_listen ( u16_t  port  )
Start listening to the specified port.
Note:
Since this function expects the port number in network byte order, a conversion using HTONS() or htons() is necessary.
Parameters:
port A 16-bit port number in network byte order.
void uip_process ( u8_t  flag  )
void uip_send ( const void *  data,
int  len
Send data on the current connection.
This function is used to send out a single segment of TCP data. Only applications that have been invoked by uIP for event processing can send data.
The amount of data that actually is sent out after a call to this funcion is determined by the maximum amount of data TCP allows. uIP will automatically crop the data so that only the appropriate amount of data is sent. The function uip_mss() can be used to query uIP for the amount of data that actually will be sent.
Note:
This function does not guarantee that the sent data will arrive at the destination. If the data is lost in the network, the application will be invoked with the uip_rexmit() event being set. The application will then have to resend the data using this function.
Parameters:
data A pointer to the data which is to be sent.
len The maximum amount of data bytes to be sent.
void uip_setipid ( u16_t  id  )
This function may be used at boot time to set the initial ip_id.
u16_t uip_tcpchksum ( void   )
Calculate the TCP checksum of the packet in uip_buf and uip_appdata.
The TCP checksum is the Internet checksum of data contents of the TCP segment, and a pseudo-header as defined in RFC793.
Returns:
The TCP checksum of the TCP segment in uip_buf and pointed to by uip_appdata.
u16_t uip_udpchksum ( void   )
Calculate the UDP checksum of the packet in uip_buf and uip_appdata.
The UDP checksum is the Internet checksum of data contents of the UDP segment, and a pseudo-header as defined in RFC768.
Returns:
The UDP checksum of the UDP segment in uip_buf and pointed to by uip_appdata.
void uip_unlisten ( u16_t  port  )
Stop listening to the specified port.
Note:
Parameters:
Variable Documentation
4-byte array used for the 32-bit sequence number calculations.
void* uip_appdata
Pointer to the application data in the packet buffer.
This pointer points to the application data when the application is called. If the application wishes to send data, the application may use this space to write the data into before calling uip_send().
void* uip_appdata
u8_t uip_buf[UIP_BUFSIZE+2]
The uIP packet buffer.
The uip_buf array is used to hold incoming and outgoing packets. The device driver should place incoming data into this buffer. When sending data, the device driver should read the link level headers and the TCP/IP headers from this buffer. The size of the link level headers is configured by the UIP_LLH_LEN define.
Note:
The application data need not be placed in this buffer, so the device driver must read it from the place pointed to by the uip_appdata pointer as illustrated by the following example:
 void
 devicedriver_send(void)
    hwsend(&uip_buf[0], UIP_LLH_LEN);
    if(uip_len <= UIP_LLH_LEN + UIP_TCPIP_HLEN) {
      hwsend(&uip_buf[UIP_LLH_LEN], uip_len - UIP_LLH_LEN);
    } else {
      hwsend(&uip_buf[UIP_LLH_LEN], UIP_TCPIP_HLEN);
      hwsend(uip_appdata, uip_len - UIP_TCPIP_HLEN - UIP_LLH_LEN);
struct uip_conn* uip_conn
Pointer to the current TCP connection.
The uip_conn pointer can be used to access the current TCP connection.
struct uip_conn uip_conns[UIP_CONNS]
The length of the packet in the uip_buf buffer.
The global variable uip_len holds the length of the packet in the uip_buf buffer.
When the network device driver calls the uIP input function, uip_len should be set to the length of the packet in the uip_buf buffer.
When sending packets, the device driver should use the contents of the uip_len variable to determine the length of the outgoing packet.
u16_t uip_listenports[UIP_LISTENPORTS]
void* uip_sappdata
The uIP TCP/IP statistics.
This is the variable in which the uIP TCP/IP statistics are gathered.
