Defines | |
| #define | uip_input() |
| #define | uip_periodic(conn) |
| #define | uip_conn_active(conn) (uip_conns[conn].tcpstateflags != UIP_CLOSED) |
| #define | uip_periodic_conn(conn) |
| #define | uip_poll_conn(conn) |
Variables | |
| u8_t | uip_buf [UIP_BUFSIZE+2] |
These functions are used by a network device driver for interacting with uIP.
| #define uip_conn_active | ( | conn | ) | (uip_conns[conn].tcpstateflags != UIP_CLOSED) |
| #define uip_input | ( | ) |
Process an incoming packet.
This function should be called when the device driver has received a packet from the network. The packet from the device driver must be present in the uip_buf buffer, and the length of the packet should be placed in the uip_len variable.
When the function returns, there may be an outbound packet placed in the uip_buf packet buffer. If so, the uip_len variable is set to the length of the packet. If no packet is to be sent out, the uip_len variable is set to 0.
The usual way of calling the function is presented by the source code below.
uip_len = devicedriver_poll(); if(uip_len > 0) { uip_input(); if(uip_len > 0) { devicedriver_send(); } }
#define BUF ((struct uip_eth_hdr *)&uip_buf[0]) uip_len = ethernet_devicedrver_poll(); if(uip_len > 0) { if(BUF->type == HTONS(UIP_ETHTYPE_IP)) { uip_arp_ipin(); uip_input(); if(uip_len > 0) { uip_arp_out(); ethernet_devicedriver_send(); } } else if(BUF->type == HTONS(UIP_ETHTYPE_ARP)) { uip_arp_arpin(); if(uip_len > 0) { ethernet_devicedriver_send(); } }
| #define uip_periodic | ( | conn | ) |
Periodic processing for a connection identified by its number.
This function does the necessary periodic processing (timers, polling) for a uIP TCP conneciton, and should be called when the periodic uIP timer goes off. It should be called for every connection, regardless of whether they are open of closed.
When the function returns, it may have an outbound packet waiting for service in the uIP packet buffer, and if so the uip_len variable is set to a value larger than zero. The device driver should be called to send out the packet.
The ususal way of calling the function is through a for() loop like this:
for(i = 0; i < UIP_CONNS; ++i) { uip_periodic(i); if(uip_len > 0) { devicedriver_send(); } }
for(i = 0; i < UIP_CONNS; ++i) { uip_periodic(i); if(uip_len > 0) { uip_arp_out(); ethernet_devicedriver_send(); } }
| conn | The number of the connection which is to be periodically polled. |
| #define uip_periodic_conn | ( | conn | ) |
Perform periodic processing for a connection identified by a pointer to its structure.
Same as uip_periodic() but takes a pointer to the actual uip_conn struct instead of an integer as its argument. This function can be used to force periodic processing of a specific connection.
| conn | A pointer to the uip_conn struct for the connection to be processed. |
| #define uip_poll_conn | ( | conn | ) |
Reuqest that a particular connection should be polled.
Similar to uip_periodic_conn() but does not perform any timer processing. The application is polled for new data.
The uIP packet buffer.
The uip_buf array is used to hold incoming and outgoing packets. The device driver should place incoming data into this buffer. When sending data, the device driver should read the link level headers and the TCP/IP headers from this buffer. The size of the link level headers is configured by the UIP_LLH_LEN define.
void devicedriver_send(void) { hwsend(&uip_buf[0], UIP_LLH_LEN); if(uip_len <= UIP_LLH_LEN + UIP_TCPIP_HLEN) { hwsend(&uip_buf[UIP_LLH_LEN], uip_len - UIP_LLH_LEN); } else { hwsend(&uip_buf[UIP_LLH_LEN], UIP_TCPIP_HLEN); hwsend(uip_appdata, uip_len - UIP_TCPIP_HLEN - UIP_LLH_LEN); } }
1.6.1
