Defines | |
| #define | uip_ipaddr(addr, addr0, addr1, addr2, addr3) |
| #define | uip_ip6addr(addr, addr0, addr1, addr2, addr3, addr4, addr5, addr6, addr7) |
| #define | uip_ipaddr_copy(dest, src) |
| #define | uip_ipaddr_cmp(addr1, addr2) |
| #define | uip_ipaddr_maskcmp(addr1, addr2, mask) |
| #define | uip_ipaddr_mask(dest, src, mask) |
| #define | uip_ipaddr1(addr) |
| #define | uip_ipaddr2(addr) |
| #define | uip_ipaddr3(addr) |
| #define | uip_ipaddr4(addr) |
| #define | HTONS(n) |
| #define | ntohs htons |
Functions | |
| u16_t | htons (u16_t val) |
| unsigned char | uiplib_ipaddrconv (char *addrstr, unsigned char *addr) |
These functions can be used for converting between different data formats used by uIP.
| #define HTONS | ( | n | ) |
Convert 16-bit quantity from host byte order to network byte order.
This macro is primarily used for converting constants from host byte order to network byte order. For converting variables to network byte order, use the htons() function instead.
| #define ntohs htons |
| #define uip_ip6addr | ( | addr, | |||
| addr0, | |||||
| addr1, | |||||
| addr2, | |||||
| addr3, | |||||
| addr4, | |||||
| addr5, | |||||
| addr6, | |||||
| addr7 | ) |
Construct an IPv6 address from eight 16-bit words.
This function constructs an IPv6 address.
| #define uip_ipaddr | ( | addr, | |||
| addr0, | |||||
| addr1, | |||||
| addr2, | |||||
| addr3 | ) |
Construct an IP address from four bytes.
This function constructs an IP address of the type that uIP handles internally from four bytes. The function is handy for specifying IP addresses to use with e.g. the uip_connect() function.
Example:
uip_ipaddr_t ipaddr; struct uip_conn *c; uip_ipaddr(&ipaddr, 192,168,1,2); c = uip_connect(&ipaddr, HTONS(80));
| addr | A pointer to a uip_ipaddr_t variable that will be filled in with the IP address. | |
| addr0 | The first octet of the IP address. | |
| addr1 | The second octet of the IP address. | |
| addr2 | The third octet of the IP address. | |
| addr3 | The forth octet of the IP address. |
| #define uip_ipaddr1 | ( | addr | ) |
Pick the first octet of an IP address.
Picks out the first octet of an IP address.
Example:
uip_ipaddr_t ipaddr; u8_t octet; uip_ipaddr(&ipaddr, 1,2,3,4); octet = uip_ipaddr1(&ipaddr);
In the example above, the variable "octet" will contain the value 1.
| #define uip_ipaddr2 | ( | addr | ) |
Pick the second octet of an IP address.
Picks out the second octet of an IP address.
Example:
uip_ipaddr_t ipaddr; u8_t octet; uip_ipaddr(&ipaddr, 1,2,3,4); octet = uip_ipaddr2(&ipaddr);
In the example above, the variable "octet" will contain the value 2.
| #define uip_ipaddr3 | ( | addr | ) |
Pick the third octet of an IP address.
Picks out the third octet of an IP address.
Example:
uip_ipaddr_t ipaddr; u8_t octet; uip_ipaddr(&ipaddr, 1,2,3,4); octet = uip_ipaddr3(&ipaddr);
In the example above, the variable "octet" will contain the value 3.
| #define uip_ipaddr4 | ( | addr | ) |
Pick the fourth octet of an IP address.
Picks out the fourth octet of an IP address.
Example:
uip_ipaddr_t ipaddr; u8_t octet; uip_ipaddr(&ipaddr, 1,2,3,4); octet = uip_ipaddr4(&ipaddr);
In the example above, the variable "octet" will contain the value 4.
| #define uip_ipaddr_cmp | ( | addr1, | |||
| addr2 | ) |
Compare two IP addresses
Compares two IP addresses.
Example:
uip_ipaddr_t ipaddr1, ipaddr2; uip_ipaddr(&ipaddr1, 192,16,1,2); if(uip_ipaddr_cmp(&ipaddr2, &ipaddr1)) { printf("They are the same"); }
| addr1 | The first IP address. | |
| addr2 | The second IP address. |
| #define uip_ipaddr_copy | ( | dest, | |||
| src | ) |
Copy an IP address to another IP address.
Copies an IP address from one place to another.
Example:
uip_ipaddr_t ipaddr1, ipaddr2; uip_ipaddr(&ipaddr1, 192,16,1,2); uip_ipaddr_copy(&ipaddr2, &ipaddr1);
| dest | The destination for the copy. | |
| src | The source from where to copy. |
| #define uip_ipaddr_mask | ( | dest, | |||
| src, | |||||
| mask | ) |
Mask out the network part of an IP address.
Masks out the network part of an IP address, given the address and the netmask.
Example:
uip_ipaddr_t ipaddr1, ipaddr2, netmask; uip_ipaddr(&ipaddr1, 192,16,1,2); uip_ipaddr(&netmask, 255,255,255,0); uip_ipaddr_mask(&ipaddr2, &ipaddr1, &netmask);
In the example above, the variable "ipaddr2" will contain the IP address 192.168.1.0.
| dest | Where the result is to be placed. | |
| src | The IP address. | |
| mask | The netmask. |
| #define uip_ipaddr_maskcmp | ( | addr1, | |||
| addr2, | |||||
| mask | ) |
Compare two IP addresses with netmasks
Compares two IP addresses with netmasks. The masks are used to mask out the bits that are to be compared.
Example:
uip_ipaddr_t ipaddr1, ipaddr2, mask; uip_ipaddr(&mask, 255,255,255,0); uip_ipaddr(&ipaddr1, 192,16,1,2); uip_ipaddr(&ipaddr2, 192,16,1,3); if(uip_ipaddr_maskcmp(&ipaddr1, &ipaddr2, &mask)) { printf("They are the same"); }
| addr2 | The second IP address. | |
This function is primarily used for converting variables from host byte order to network byte order. For converting constants to network byte order, use the HTONS() macro instead.
| unsigned char uiplib_ipaddrconv | ( | char * | addrstr, | |
| unsigned char * | addr | |||
Convert a textual representation of an IP address to a numerical representation.
This function takes a textual representation of an IP address in the form a.b.c.d and converts it into a 4-byte array that can be used by other uIP functions.
| addrstr | A pointer to a string containing the IP address in textual form. | |
| addr | A pointer to a 4-byte array that will be filled in with the numerical representation of the address. |
| 0 | If the IP address could not be parsed. | |
| Non-zero | If the IP address was parsed. |
1.6.1
