#include <uip.h>
The structure holding the TCP/IP statistics that are gathered if UIP_STATISTICS is set to 1.
Number of TCP segments with a bad ACK number.
Number of packets dropped due to IP checksum errors.
Number of TCP segments with a bad checksum.
Number of dropped packets at the IP layer.
Number of dropped ICMP packets.
Number of dropped TCP segments.
Number of packets dropped since they were IP fragments.
Number of packets dropped due to wrong IP length, high byte.
| struct { ... } uip_stats::icmp |
ICMP statistics.
| struct { ... } uip_stats::ip |
IP statistics.
Number of packets dropped due to wrong IP length, low byte.
Number of packets dropped since they were neither ICMP, UDP nor TCP.
Number of received packets at the IP layer.
Number of received ICMP packets.
Number of recived TCP segments.
Number of retransmitted TCP segments.
Number of recevied TCP RST (reset) segments.
Number of sent packets at the IP layer.
Number of sent ICMP packets.
Number of sent TCP segments.
Number of dropped SYNs due to too few connections was avaliable.
Number of SYNs for closed ports, triggering a RST.
| struct { ... } uip_stats::tcp |
TCP statistics.
Number of ICMP packets with a wrong type.
Number of packets dropped due to wrong IP version or header length.
1.6.1
