Data Structures |
| union | sysex_runtime_var_t |
| union | extra_par_available_t |
| struct | mbng_event_pool_item_t |
| struct | mbng_event_pool_map_t |
Defines |
| #define | MBNG_EVENT_POOL_MAX_SIZE (24*1024) |
| #define | MBNG_EVENT_NRPN_RECEIVE_PORTS_MASK 0x00ff |
| #define | MBNG_EVENT_NRPN_RECEIVE_PORTS_OFFSET 0 |
| #define | MBNG_EVENT_NRPN_RECEIVE_PORTS 8 |
| #define | MBNG_EVENT_NRPN_RECEIVE_CHANNELS 16 |
| #define | MBNG_EVENT_NRPN_SEND_PORTS_MASK 0x00f0 |
| #define | MBNG_EVENT_NRPN_SEND_PORTS_OFFSET 4 |
| #define | MBNG_EVENT_NRPN_SEND_PORTS 4 |
| #define | MBNG_EVENT_NRPN_SEND_CHANNELS 16 |
| #define | LC_METERS_NUM_PORTS 8 |
| #define | LC_METERS_NUM_ITEMS 8 |
| #define | STREAM_MAX_SIZE 128 |
| #define | MBNG_EVENT_ADD_STREAM(b) { if( len < STREAM_MAX_SIZE ) { *stream_out = b; ++len; chk += *stream_out++; } } |
Functions |
| s32 | MBNG_EVENT_Init (u32 mode) |
| s32 | MBNG_EVENT_Tick (void) |
| s32 | MBNG_EVENT_PoolClear (void) |
| s32 | MBNG_EVENT_PoolUpdate (void) |
| s32 | MBNG_EVENT_PoolPrint (void) |
| s32 | MBNG_EVENT_PoolItemsPrint (void) |
| s32 | MBNG_EVENT_PoolMapsPrint (void) |
| s32 | MBNG_EVENT_PoolNumItemsGet (void) |
| s32 | MBNG_EVENT_PoolNumMapsGet (void) |
| s32 | MBNG_EVENT_PoolSizeGet (void) |
| s32 | MBNG_EVENT_PoolMaxSizeGet (void) |
| s32 | MBNG_EVENT_MapAdd (u8 map, mbng_event_map_type_t map_type, u8 *map_values, u8 len) |
| s32 | MBNG_EVENT_MapGet (u8 map, mbng_event_map_type_t *map_type, u8 **map_values) |
| s32 | MBNG_EVENT_MapValue (u8 map, u16 value, u16 range, u8 reverse_interpolation) |
| s32 | MBNG_EVENT_MapItemValueInc (u8 map, mbng_event_item_t *item, s32 incrementer, u8 auto_wrap) |
| s32 | MBNG_EVENT_MapIxFromValue (mbng_event_map_type_t map_type, u8 *map_values, u8 map_len, u8 value) |
| s32 | MBNG_EVENT_NumBanksGet (void) |
| s32 | MBNG_EVENT_SelectedBankGet (void) |
| s32 | MBNG_EVENT_SelectedBankSet (u8 new_bank) |
| s32 | MBNG_EVENT_HwIdBankGet (u16 hw_id) |
| s32 | MBNG_EVENT_HwIdBankSet (u16 hw_id, u8 new_bank) |
| s32 | MBNG_EVENT_ItemNoDumpDefault (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemInit (mbng_event_item_t *item, mbng_event_item_id_t id) |
| s32 | MBNG_EVENT_ItemGet (u32 item_ix, mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemAdd (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemModify (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemSearchById (mbng_event_item_id_t id, mbng_event_item_t *item, u32 *continue_ix) |
| s32 | MBNG_EVENT_ItemSearchByHwId (mbng_event_item_id_t hw_id, mbng_event_item_t *item, u32 *continue_ix) |
| s32 | MBNG_EVENT_ItemRetrieveValues (mbng_event_item_id_t *id, s16 *value, u8 *secondary_value, u32 *continue_ix) |
| s32 | MBNG_EVENT_ItemCopyValueToPool (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemSetActive (mbng_event_item_t *item, u8 active) |
| s32 | MBNG_EVENT_ItemSetNoDump (mbng_event_item_t *item, u8 no_dump) |
| s32 | MBNG_EVENT_ItemSetLock (mbng_event_item_t *item, u8 lock) |
| s32 | MBNG_EVENT_ItemSetMapIx (mbng_event_item_t *item, u8 map_ix) |
| s32 | MBNG_EVENT_ItemCheckMatchingCondition (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemPrint (mbng_event_item_t *item, u8 all) |
| s32 | MBNG_EVENT_ItemSearchByIdAndPrint (mbng_event_item_id_t id) |
| s32 | MBNG_EVENT_ItemSearchByHwIdAndPrint (mbng_event_item_id_t hw_id) |
| s32 | MBNG_EVENT_LCMeters_Init (void) |
| s32 | MBNG_EVENT_MidiLearnModeSet (u8 mode) |
| s32 | MBNG_EVENT_MidiLearnModeGet (void) |
| s32 | MBNG_EVENT_MidiLearnStatusMsg (char *line1, char *line2) |
| s32 | MBNG_EVENT_MidiLearnIt (mbng_event_item_id_t hw_id) |
| s32 | MBNG_EVENT_EventLearnIdSet (mbng_event_item_id_t id) |
| mbng_event_item_id_t | MBNG_EVENT_EventLearnIdGet (void) |
| s32 | MBNG_EVENT_EventLearnStatusMsg (char *line1, char *line2) |
| s32 | MBNG_EVENT_EventLearnIt (mbng_event_item_t *item, u16 prev_value) |
| const char * | MBNG_EVENT_ItemControllerStrGet (mbng_event_item_id_t id) |
| mbng_event_item_id_t | MBNG_EVENT_ItemIdFromControllerStrGet (char *event) |
| const char * | MBNG_EVENT_ItemTypeStrGet (mbng_event_item_t *item) |
| mbng_event_type_t | MBNG_EVENT_ItemTypeFromStrGet (char *event_type) |
| const char * | MBNG_EVENT_ItemConditionStrGet (mbng_event_item_t *item) |
| mbng_event_if_cond_t | MBNG_EVENT_ItemConditionFromStrGet (char *condition) |
| const char * | MBNG_EVENT_ItemButtonModeStrGet (mbng_event_item_t *item) |
| mbng_event_button_mode_t | MBNG_EVENT_ItemButtonModeFromStrGet (char *button_mode) |
| const char * | MBNG_EVENT_ItemAinModeStrGet (mbng_event_item_t *item) |
| mbng_event_ain_mode_t | MBNG_EVENT_ItemAinModeFromStrGet (char *ain_mode) |
| const char * | MBNG_EVENT_ItemAinSensorModeStrGet (mbng_event_item_t *item) |
| mbng_event_ain_sensor_mode_t | MBNG_EVENT_ItemAinSensorModeFromStrGet (char *ain_sensor_mode) |
| const char * | MBNG_EVENT_ItemEncModeStrGet (mbng_event_enc_mode_t enc_mode) |
| mbng_event_enc_mode_t | MBNG_EVENT_ItemEncModeFromStrGet (char *enc_mode) |
| const char * | MBNG_EVENT_ItemEncSpeedModeStrGet (mbng_event_item_t *item) |
| mbng_event_enc_speed_mode_t | MBNG_EVENT_ItemEncSpeedModeFromStrGet (char *enc_speed_mode) |
| const char * | MBNG_EVENT_ItemLedMatrixPatternStrGet (mbng_event_item_t *item) |
| mbng_event_led_matrix_pattern_t | MBNG_EVENT_ItemLedMatrixPatternFromStrGet (char *led_matrix_pattern) |
| const char * | MBNG_EVENT_ItemNrpnFormatStrGet (mbng_event_item_t *item) |
| mbng_event_nrpn_format_t | MBNG_EVENT_ItemNrpnFormatFromStrGet (char *nrpn_format) |
| const char * | MBNG_EVENT_ItemSysExVarStrGet (mbng_event_item_t *item, u8 stream_pos) |
| mbng_event_sysex_var_t | MBNG_EVENT_ItemSysExVarFromStrGet (char *sysex_var) |
| const char * | MBNG_EVENT_ItemMetaTypeStrGet (mbng_event_meta_type_t meta_type) |
| mbng_event_meta_type_t | MBNG_EVENT_ItemMetaTypeFromStrGet (char *meta_type) |
| u8 | MBNG_EVENT_ItemMetaNumBytesGet (mbng_event_meta_type_t meta_type) |
| s32 | MBNG_EVENT_SendOptimizedNRPN (mios32_midi_port_t port, mios32_midi_chn_t chn, u16 nrpn_address, u16 nrpn_value, u8 msb_only) |
| s32 | MBNG_EVENT_SendSysExStream (mios32_midi_port_t port, mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ExecMeta (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemSend (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemSendVirtual (mbng_event_item_t *item, mbng_event_item_id_t send_id) |
| s32 | MBNG_EVENT_ItemReceive (mbng_event_item_t *item, u16 value, u8 from_midi, u8 fwd_enabled) |
| s32 | MBNG_EVENT_ItemForward (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_ItemForwardToRadioGroup (mbng_event_item_t *item, u8 radio_group) |
| s32 | MBNG_EVENT_NotifySendValue (mbng_event_item_t *item) |
| s32 | MBNG_EVENT_Refresh (void) |
| s32 | MBNG_EVENT_UpdateLCD (u8 force) |
| s32 | MBNG_EVENT_Dump (void) |
| s32 | MBNG_EVENT_MIDI_NotifyPackage (mios32_midi_port_t port, mios32_midi_package_t midi_package) |
| s32 | MBNG_EVENT_ReceiveSysEx (mios32_midi_port_t port, u8 midi_in) |
Variables |
| mbng_event_item_id_t | last_event_item_id |
