clock2audio2clock
clk2a2clk
Midiclock 2 Audio Converter, Audio 2 Midiclock Converter
4 Recording a Midiclock on a Audio-Track on your Multitrack-Recording-Device
in order to get the possibility to overdub a sequencer track on Recording Devices without Midi-Clock builtin
Introduction
i fell in love with a zoom livetrack-l12, a multitrack-audio-recorder, in a compact design, severell submixes, parametric eqs, compressor, efx and a extra master-track-recording, and that for a good price…
but it doesnt have midi… in specially it does not have a midiclock.
so when i have to make a track new, or i want to overdub a track, a track that is Midiclock-Driven a sequencer track for example…
So with this device, i lose one Audio-Track, because i use this one Audio-Track, as a Click-Track, it records Audio-Rectangle-Pulses, which are a converted Midiclock-Pulses
when i then playback the Click-Track-Recording, it converts this Audio Pulses back to Midiclock-Messages.
Thats all, not much code, stripped down, running thight.
Features
- convert Midi-Clock-Data to Audio-Pulses
convert Audio-Pulses to Midi-Clock-Data
Hardware Requirements
  • Clock Source aka Sequencer: midibox_seq_v4l
  • a Synth: JP8080
  • a Multitrack-Audio-Recorder: Zoom Livetrack L12
  • 3x Midi-Cables
Midibox:
Schmitt-Trigger:
  • TS-274 OP-Amp
  • 14 Pin - DIP-Socket
  • Pin-Header 2x5Pins (to connect the PCB to Core J5A)(you will also need a cable 4 that)
  • Resistor R1 20K
  • Resistor R2 4K7
  • Resistor RFB 100K
  • Resistor for Output-Gain-Reduction 100K
  • 2x Electrolyt Capacitor 0,67uF (to decouple audio in and out)
  • Electrolyt Capacitor 10uF for Supply
  • Capacitor 100nF to denoise the OP-Amps-Rails…
  • 2 Audio Cables+Sockets for the connection to the Recorder (6,3 mono jacks)
on Protoboard
here i have made it all on protoboard:
Frontpanels
MBHP
Software
Firmware
V1.2017clk2a2clk.zip hardcodet no menue, no nothing, stripped down to max performance
How I Use It - built in Rack
Resources
Community users working on it
  • Phatline = Programming, Documentation…
clock2audio2clock.1527217596.txt.gz · Last modified: 2018/05/25 03:06 by phatline
