lre-oled-bar
LRE8x2 096 SSD1306-BAR for Eurorack
I made this PCBs to use it with Fairlightii´s mb-lre8x2cs_pcb
4x PCBs on one 100x100mm
there is no V-Groove, you have to cut it on the marking
groove it on top and back, with a new sharp cutter, do it several times, then break it
With this Method you pay for 20 PCBs 8€ all inclusive to EU-Austria
So you can Stuff 5 LRE8x2 with this.
Here are the gerberfiles for production - i made it withJLCPCB
lre-oled-reva-gerber.zip
And they are working, they also V-Grooved on my marking without extra costs…
My next Revision would be a Micromatch header on the left side of the pcbs so i can directly interconnect to a Display Driver (crimping instead of soldering)
Hardware Requirements
  • a MIOS32 Core to connect too
  • Soldering Iron - with a Dip that can Handle Thruhole-Parts, solder Paste…
  • LRE8x2 for its nature use
Shematic
Building and BOM
The Values are printet on the PCB.
Following Quantity is for 4 PCBs:
8x 1Row 7Pin headers (2.54mm pitch)
8x 1K 1208 SMD Resistors
12x 10uF 1208 Capacitors (non polarized)
3x 10K 0603 SMD Resistors which are optional
8x 0.96“ SSD1306 Screens
Frontpanel
I made a DXF File which you can send to Formulor in Germany
i panalized it so there are 2 Plates in it
I payed 40€ summed for booth plates incl shipping from Germany to Austria
The Version with the not needet 3mm Mounting holes for the LRE8x2:2xlre-oled-bar-dxf.zip
My Orginal Autocad Drawing, + DXFs for Fabrication without the non needet Mounting Holes:euro-lre-frontpanel.zip
Recommend Material from Formulor:
3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)
To Do
The LRE-OLED-Bar & The Frontpanel are a Part of my MSQ-CC-LRE-V2
so look there for more information….
Community users working on it
  • Phatline = PCB & Shematic, UI-Programming, Documentation…
lre-oled-bar.txt · Last modified: 2022/02/04 14:22 by phatline
