tm5-gateinput
TM5 Gate/Trigger Input
this is one essential part for my triggermatrix5
* Levelshift from 5V to the for the MCU required 3V, with a Resistor Divider
* Overvoltage Protectect with TVS-Diodes
* Preamp-Section
5V, 3V or Pre-Amped input - can be set vie Jumpers and Potentiometers, the PCB itself should be mounted on the Groundplate off the housing, the housing should have a service-plate to access this Settings!:
8 Channels, are managed here, so in order to have 16channels, you need 2 off this PCBs
if you dont want a Preamp, then dont stuff the Preamp-section > this will make this PCB a lot off cheaper!
Shematic
Building and BOM
BOM
Follwing list is for reference, and debugging only, no need to order them! all the parts are already soldered on the PCB!
Comment Designator Footprint LCSC
10uF C1-18,C34-54 0805_C CL21A106KAYNNNE
100n C19-33 0402_C C307331
- CS1,LCD1-18,inB10,outB10,in15 PinHead-SMD-2,54mm Pitch C192300
SN74HC541 IC1-7 SOIC127P780X200-20N C116811
74HC595 IC8-10 SOIC-16 C5947
220 OHM R1-54 0402_R C25091
1K OHM R55-96 0402_R C11702
Order-List
copy following list into this mouser.com-Link
710-61200823021|22
Order from Reichelt:
17xFemale Pinheader 1x7pin
To Do
waiting for the assembled Prototype
Community users working on it
  • Phatline = PCB & Shematic, UI-Programming, Documentation…
tm5-gateinput.1672314645.txt.gz · Last modified: 2022/12/29 11:50 by phatline
