TriggerMatrix V4
CODE, FIRMWARE
Install MIOS Studio, connect TM4 via USB, and Start the STUDIO
1. Upload MIOS BOOTLOADER
2. (only needet for Virgin Machines) type following commands into the MIOS-TERMINAL:
- set lcd_type GLCD_SSD1306_ROTATED
 - set lcd_num_x 9
 - set lcd_num_y 1
 - set lcd_width 128
 - set lcd_height 64
 - store
3. (for Version Updates) Unzip the TM4-Firmware, and Upload the TM4.hex
4. Unconnect USB & Connect the USB again — finished.
5. If the Machine is not detected by mios studio, and you already checked the usb-connections, the device or the code is broken, for that on the backside of TM4 is a switch, please set it to “bLOAD”, now you can upload new & unbroken codes, dont forget to set it to “normal” back again - after upload new code - else the APP will not boot…
BUILD
BOM, Components, PCBs
- Full Sized SD-CARD, which is not Hi-Capacity, eg take 4 or 8GB Cards!
 - 2x Wood: 15 x 400 x 39mm, or > 16 x 400 x 39mm (39mm is minimal, i took 40mm…)
 - 1x Wood: 15 x 335 x 39mm, or > 16 x 333 x 39mm (39mm is minimal, i took 40mm…)
 - 3mm Alu Plates for Ground and Backpanel (you cut and drill it by your own)
 - 3mm Alu Frontpanel, CNC-machined (See DXF-File for more info)
Pictured Doku
BLM16x16
Code-Block
Labels:
Wires:
Wood-Elements:
15mm “hard-Wood”, i use BEECH, let it cut by your local hardwarestore…
Features
Short spoken:
- 16xdrumtriggers > Trigger-Routing-Matrix > Drum-Syntesizers
 - 5x Poly Melody-lines > Trigger-Routing-Matrix > Melody-Syntesizers (track 1-5)
 - 7x Mono Melody-lines > Trigger-Routing-Matrix > Melody-Syntesizers/Pitachable Drums (track 6-12)
Rules:
- Drum-Trigger are Velocity Master > we dont care about the velocity of the Melodys
 - There are Songs (ProgramChange), each Song has 8 different Trigger-Routings Presets> these are the Song-Parts
 - Each Song has 4 StepSequencer-Variants (Rythms)
 - Each Song can Remote up to 6 Melody Scenes (LoopA-compatible!)
 - 256 Songs saved on SD-Card, and Load-able while playing
 - The Tempo has to be changed by Hand or Midi, it is not saved with the song
 - System-Settings, like Ports or MidiChannels are Hardcodet, but there will be a sys-menue in near future
 - Triggermatrix midi-outs are connected to all synths, so it manage the program-change also
 - 16x Trigger-OUTs with fixed Notes, on one midichannel - to connect Drum-Synths, Drum-Samplers
 - 5x Polyphonic Melody-Retrigger-OUTs on 5 MidiChannels - to connect MelodySynths to it
 - 7x Monophonic Melody-Retrigger-OUTs on 7 MidiChannels - to connect Monophonic Synths like pitchable Drums or Bass-Synths
- i think 1-5 is poly the rest is mono!
 - All 16 Trigger & ReTrigger-OUTs share the same Routing and Channelstrip UI (Mute, Solo, Roll…)
 - Trigger, Poly, Mono-OUTs can be controlled seperatly by > Random-Kill & Velocity-OFFSet
 - 5×16 Melody-Input-Matrix - Route & Mix Melody Inputs to the 16 Melody-Retrigger-Outs (saved in Song)
 - 16x Melody-Input-Matrix-Hold-Buttons - hold the last Note, save it in the Patch - usefull when pitch drums.
the Matrix has also a Trigger-Sequencer built in, the Melodys have to come from anywhere else, but @ the end, they have to be plugged into the matrix…
Trigger-sequencer, a few facts:
- is a Drum-Step-Sequencer
 - 256 Steps in total
 - 32 th fixed rate
 - 3,4,5,7,11,13/4 tact
 - minimal LoopSection is 16steps = 1 Page, there are 16 pages to chain
 - intro LoopSection, from step 0 until to the “minimal LoopSection”- is played once, then it loops the normal LoopSection
 - The sequencer is made to give a static NoteStream, the Song-Structure is done LIVE by the TriggerMatrix-ROUTER
 - Full Velocity control, visible with 3 different colours, Velocity Set via FADER
 - Free programmable Swing to each Step, with 2 different swing Length-sets, which are controlled live with encoder
 - copy, paste, erase of pages
 - copy, paste, erase of rows
 - fixed forward play direction
Community users working on it
- Phatline = Programming, Documentation, Hardware-Prototype, Testing, Jamin…
 - Maxim Anokhin - as first User of TM4 - Serial Nr.1
Getting Involved ?
