#include <mios32.h>#include <string.h>#include <uip_task.h>#include <midi_port.h>#include "tasks.h"#include "file.h"#include "mbng_file.h"#include "mbng_file_r.h"#include "mbng_patch.h"#include "mbng_event.h"#include "mbng_lcd.h"Data Structures | |
| struct | mbng_file_r_info_t |
| union | mbng_file_r_req_t |
| struct | mbng_file_r_var_t |
| union | mbng_file_r_item_id_t |
Defines | |
| #define | DEBUG_VERBOSE_LEVEL 1 |
| #define | DEBUG_FILE_HANDLER_PERFORMANCE 0 |
| #define | NGR_TOKENIZED 0 |
| #define | IF_MAX_NESTING_LEVEL 16 |
| #define | TOKEN_MATH_BEGIN TOKEN_MATH_PLUS |
| #define | TOKEN_MATH_END TOKEN_MATH_XOR |
| #define | MBNG_FILES_PATH "/" |
| #define | STREAM_MAX_SIZE 256 |
Enumerations | |
| enum | ngr_token_t { TOKEN_NOP = 0, TOKEN_EXIT = 0x01, TOKEN_DELAY_MS = 0x02, TOKEN_LCD = 0x03, TOKEN_LOG = 0x04, TOKEN_SEND = 0x05, TOKEN_EXEC_META = 0x06, TOKEN_SET = 0x07, TOKEN_CHANGE = 0x08, TOKEN_TRIGGER = 0x09, TOKEN_SET_RGB = 0x0a, TOKEN_SET_HSV = 0x0b, TOKEN_SET_LOCK = 0x0c, TOKEN_SET_ACTIVE = 0x0d, TOKEN_SET_NO_DUMP = 0x0e, TOKEN_SET_MIN = 0x0f, TOKEN_SET_MAX = 0x10, TOKEN_IF = 0x80, TOKEN_ELSE = 0x81, TOKEN_ELSEIF = 0x82, TOKEN_ENDIF = 0x84, TOKEN_COND_EQ = 0x90, TOKEN_COND_NE = 0x91, TOKEN_COND_GTEQ = 0x92, TOKEN_COND_LTEQ = 0x93, TOKEN_COND_GT = 0x94, TOKEN_COND_LT = 0x95 } |
Functions | |
| s32 | MBNG_FILE_R_Init (u32 mode) |
| s32 | MBNG_FILE_R_Load (char *filename) |
| s32 | MBNG_FILE_R_Unload (void) |
| s32 | MBNG_FILE_R_Valid (void) |
| s32 | MBNG_FILE_R_TokenizedNgrSet (u8 enable) |
| s32 | MBNG_FILE_R_TokenizedNgrGet (void) |
| s32 | MBNG_FILE_R_TokenMemPrint (void) |
| s32 | MBNG_FILE_R_VarSectionSet (u8 section) |
| s32 | MBNG_FILE_R_VarSectionGet () |
| s32 | MBNG_FILE_R_VarValueSet (u8 value) |
| s32 | MBNG_FILE_R_VarValueGet () |
| s32 | lineIsEmpty (char *line) |
| s32 | parseCondition (u32 line, char *command, char **brkt, u8 tokenize_req) |
| s32 | sendTokenized (mios32_midi_port_t port, mbng_event_type_t event_type, u8 *stream, u32 stream_size) |
| s32 | parseSend (u32 line, char *command, char **brkt, u8 tokenize_req) |
| s32 | parseExecMeta (u32 line, char *command, char **brkt, u8 tokenize_req) |
| s32 | setTokenizedValue (ngr_token_t token, u16 id, s32 value, s32(*exec_function)(mbng_event_item_t *item, s32 value), s32(*exec_virtual_function)(mbng_event_item_id_t id, s32 value)) |
| s32 | parseCommand (u32 line, char *command, char **brkt, u8 tokenize_req, ngr_token_t command_token, s32(*exec_function)(mbng_event_item_t *item, s32 value), s32(*exec_virtual_function)(mbng_event_item_id_t id, s32 value)) |
| s32 | parseDelay (u32 line, char *command, char **brkt, u8 tokenize_req) |
| s32 | parseLoad (u32 line, char *command, char **brkt, char *load_filename, u8 tokenize_req) |
| s32 | MBNG_FILE_R_Parser (u32 line, char *line_buffer, u8 *if_state, u8 *nesting_level, char *load_filename, u8 tokenize_req) |
| s32 | MBNG_FILE_R_Exec (u8 cont_script, u8 determine_if_offsets) |
| s32 | MBNG_FILE_R_Read (char *filename, u8 cont_script, u8 tokenize_req) |
| s32 | MBNG_FILE_R_ReadRequest (char *filename, u8 section, s16 value, u8 notify_done) |
| s32 | MBNG_FILE_R_CheckRequest (void) |
| s32 | MBNG_FILE_R_RunStop (void) |
Variables | |
| char | mbng_file_r_script_name [MBNG_FILE_R_FILENAME_LEN+1] |
| #define STREAM_MAX_SIZE 256 |
| #define TOKEN_MATH_BEGIN TOKEN_MATH_PLUS |
| #define TOKEN_MATH_END TOKEN_MATH_XOR |
1.6.1
